08-20-2013 12:50 AM - edited 03-16-2019 06:57 PM
I have a cucm 9.1.1.20000-5 version in my office and I have a corporate address book which works fine on all the users phone.
I got a request from my seniors to create a personal address book for few users.
I created a new personal address book and assosoaited it with end user.Users are able to access the end user management page and add new personal contacts.It gets saved and we can see the name and contact on the phone in new personal add book.
The problem which I am facing is the third digit automatically strip off when we dial a number from a new personal address book
For Example: let's say I have a contact name and a mobile number that is 9823456789 saved in my new personal address book when I dial this number the call goes like 983456789 so the third digit is stripped off.
So we did some changes and tried saving 98223456789 instead of 9823456789 and tried dialing then the call goes smoothly and the number is dialed is 9823456789.
Is it a bug in 9.1.1? or a wrong parameter configured by our side..?
08-20-2013 06:52 AM
Duplicate post #1
08-20-2013 09:03 AM
Are u able to dial this number correctly without PAB?
regds,
aman
08-20-2013 10:04 AM
I was not able to post this issue due to some connectivity issue so may be that was the reason my post is submited 3 times and even my coworker tried posting it
08-20-2013 10:07 AM
due to some connectivity issue my post is submited 3 to 4 times but It is not a duplicate post I would like to get help in this issue
08-20-2013 10:26 AM
Hello Alex,
Are you seeing this isuse for all the end users or only a few? Can you please give the phone model in picture here?
Avinash
08-21-2013 09:46 AM
Hi all
The phone model we are using is 6945 and we use first line we are able to dial the number directly without any issue only from the personal address book which we have creatded we are facing issue
If we have the same number from our corporate dir we can dial it but if the same number we save in the new created personal address book we get issue
I have checked the route pattern and it is not related to that.
Kindly advice some Troubleshooting steps or any doc....
08-20-2013 03:50 PM
Are you able to dial directly to these number? I mean,if you not using the Address Book, does it work?
Cheers
Bruno Rangel
Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
08-21-2013 09:46 AM
Hi all
08-21-2013 02:02 PM
Hi Alex
If there no Translate Pattern or anything like that, you can check this Bug CSCty16495... Not sure if this is your case
Cheers
Bruno Rangel
09-26-2013 09:01 AM
I encounter this case too. In CUCM same version.
The problem occure in 6945 but not found in 8941!!!
Cloud you tell me how to solve the problem?
