Showing results forĀ
Search instead forĀ
Did you mean:Ā
Phone 7821 not getting IP from voice VLAN
Hi ,
I have an issue on cisco ip phone 7821 model only. There are more than 20 phones(7821) connected  to  cisco 4503-E switch. These phones are not taking IP from Voice Vlan . even we tried to give manual IP (Voice VLAN) to the phone and it is not getting registered and ping also unsuccessful.
But, once switch port is given  switch port access vlan <ID> phone get IP from the ID which we give. Even if Voice VLAN ID given to (Sw port acc vlan ) it get registered.
Please suggest why phone not getting IP from sw port voice vlan <ID>?
Chris Deren
Is there proper DHCP scope defined for the voice vlan?
Is CDP properly enabled on your switch? Do phones show up when you issue "sh cdp neighbors"?
Dear Chris,
Thanks for your reply.
Please find the answer below:
Yes, DHCP scope defined for voice vlan. because there are other phone model (ex:7965 ) working fine to this switch ports. It takes IP address from voice vlan as  DHCP scope.Only 7821 having issue.
Yes , we can see the all phone MAC address(Include 7821) by giving "sh cdp neighbors".
What we find more on this is, when we give voice vlan only in switch port and give shut and no shut .. phone get registered. after that we can give access vlan for data and PC will get data IP same. So unless until we unplug the phone both device(Phone and PC) works fine.  Once we unplug and reconnect phone will not get an IP but PC works.
switch version details are below:
HOAS4F06#show ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.03.00.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sun 15-Apr-12 09:07 by prod_rel_team
ROM: 15.0(1r)SG5
HOAS4F06 uptime is 1 day, 4 hours, 2 minutes
Uptime for this control processor is 1 day, 4 hours, 4 minutes
System image file is "bootflash:cat4500e-universal.SPA.03.03.00.SG.151-1.SG.bin"
Jawa Revision 7, Snowtrooper Revision 0x0.0x1C
License Information for 'WS-X45-SUP7-E'
    License Level: lanbase   Type: Permanent
    Next reboot license Level: lanbase
cisco WS-C4510R+E (MPC8572) processor (revision 10) with 2097152K/20480K bytes of memory.
Processor board ID FXS1709Q1RC
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from PowerUp
2 Virtual Ethernet interfaces
288 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
strange thing is, other Phone model 7965 work fine this switch without any issue..
Please advise..
Shakeer
Dear Chris,
HOAS4F06#show ver
ROM: 15.0(1r)SG5
Please advise..
Shakeer
