10-21-2023 03:20 AM
We have a CME v12.0 running on router 2921, and I uploaded the phone 7821 firmware to the router and found the message on the router that the upgrade failed, I don't know why it failed, any suggestions?
tftp-server flash:cmterm-78xx.14-2-1-0101-26/kern2.78xx.14-2-1-0101-26.sbn
tftp-server flash:cmterm-78xx.14-2-1-0101-26/kern78xx.14-2-1-0101-26.sbn
tftp-server flash:cmterm-78xx.14-2-1-0101-26/rootfs2.78xx.14-2-1-0101-26.sbn
tftp-server flash:cmterm-78xx.14-2-1-0101-26/rootfs78xx.14-2-1-0101-26.sbn
tftp-server flash:cmterm-78xx.14-2-1-0101-26/sboot2.78xx.14-2-1-0101-26.sbn
tftp-server flash:cmterm-78xx.14-2-1-0101-26/sboot78xx.14-2-1-0101-26.sbn
tftp-server flash:cmterm-78xx.14-2-1-0101-26/sip78xx.14-2-1-0101-26.loads
also add this command under the
voice register global
Load 7821 sip78xx.14-2-1-0101-26
the screenshot is attached.
10-21-2023 05:48 AM
Hello @Faisal.Saoud,
Please provide us these output during an upgrade attempt:
#debug tftp event
#debug ccsip messages
10-23-2023 04:15 AM
Hi M02@rt37
Kindly find attached
10-23-2023 04:27 AM
I also see the phone send REFER message with 400 bad request resonse
Oct 23 11:21:28.218: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:192.168.32.28 SIP/2.0
Via: SIP/2.0/UDP 192.168.32.100:5060;branch=z9hG4bK07b1e876
From: "Faizan Ahmed" <sip:1333@192.168.32.100>;tag=9c57adb5d6ae00044d5067ae-35f3f569
To: <sip:192.168.32.28>
Call-ID: 9c57adb5-d6ae0004-20205888-4eaf2fb9@192.168.32.100
Date: Mon, 23 Oct 2023 11:21:27 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP7821/10.3.1
Expires: 10
Max-Forwards: 70
Contact: <sip:7CE0-1BED@192.168.32.100:5060;transport=udp>
Require: norefersub
Referred-By: "Faizan Ahmed" <sip:1333@192.168.32.100>
Refer-To: cid:3e5892bc@192.168.32.100
Content-Id: <3e5892bc@192.168.32.100>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 1442
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEP9C57ADB5D6AE</String>
<String name="DeviceIPv4Address">192.168.32.100/24</String>
<String name="IPv4DefaultGateway">192.168.32.4</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-7821</String>
<String name="NeighborIPv4Address">192.168.32.25</String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID">KKIA25</String>
<String name="NeighborPortID">GigabitEthernet1/0/13</String>
<Enum name="DHCPv4Status">1</Enum>
<Enum name="DHCPv6Status">3</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">4</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<Enum name="DNSv6StatusUnifiedCM1">0</Enum>
<Enum name="DNSv6StatusUnifiedCM2">0</Enum>
<Enum name="DNSv6StatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN">1</String>
<String name="UnifiedCMIPAddress">192.168.32.28</String>
<String name="LocalPort">0</String>
<String name="TimeStamp">1698060041061</String>
<Enum name="ReasonForOutOfService">22</Enum>
<String name="LastProtocolEventSent">Sent:SIP/2.0 200 OK Cseq:101 NOTIFY CallId:90BAED8-70CD11EE-993E8346-5029F783@192.168.32.28</String>
<String name="LastProtocolEventReceived"></String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Timestamp: 3780904888218
UTC Timestamp:3780904888218
Source Filename: rbtCEDB.tmp
Sent:
SIP/2.0 400 Bad Request
To: <sip:192.168.32.28>;tag=49C5824-26D2
Date: Mon, 23 Oct 2023 11:21:28 GMT
Server: Cisco-SIPGateway/IOS-15.7.3.M8
CSeq: 1000 REFER
Content-Length: 0
Contact: <sip:192.168.32.28:5060>
11-05-2023 08:32 AM
the REFER message received a "400 Bad Request" response from the SIP gateway (Server: Cisco-SIPGateway/IOS-15.7.3.M8). The "400 Bad Request" response typically indicates that the request is malformed or not understood by the server.
The SIP gateway (Cisco-SIPGateway/IOS-15.7.3.M8) may have limitations or specific requirements for REFER messages. Ensure that the Cisco IOS version is up-to-date and compatible with the phone's firmware.
Also, I see tlv file request on your tftp debug ; TLV files contain a list of trusted CA certificates and are used to verify the authenticity of the TLS server certificates presented by the IP phone during secure communication with the CME. You are not on a secure mode ? If not, try a full reset of the phone and/or go to "Security Profile" on the phone menu, and ensure that it is in "Non-secure".
11-05-2023 12:43 AM
M02@rt37 Could you please look at the debug
11-05-2023 10:27 AM
Try to upgrade the IP phone without CME router, use a TFTP client on your PC. Edit the TFTP configuration on the IP phone to point to the TFTP client's IP address. If the phone downloads and upgrades the firmware, at that time verify the CME router's IOS version is up to date, as mentioned by M02@rt37 .
