Showing results forĀ
Search instead forĀ
Did you mean:Ā
phone 7970G factory reset
Rosa Ladeira
Does anybody know how to factory reset 7970G ?
I have upgraded CUCM to 8.6 and specifically 2 phones can not upgrade each softwares before booting.
I am supposing there is a kind of bios on these phones that are not working fine.
Rosa
17 Replies 17
david
In order to factory reset a Cisco 7941/7942/7961/7962/7970/7971/7975 hardphone (third generation) use the following sequence:
Please note that this process might  take up to 10 minutes for the phone to fully recover. Make sure that option 150 is present in the network plug that is being used.
Step 1 Unplug the power cable from the phone and then plug it back in.The phone begins its power up cycle.
Step 2 While the phone is powering up, and before the Speaker button flashes on and off, press and hold #.
Continue to hold # until each line button flashes on and off in sequence in amber/orange.
Step 3a Release # and press 123456789*0# for soft reset (deletes key files on the phone including /etc/init.tab - reboots - phone recovers default loads file from TFTP server).
or
Step 3b Release # and press 3491672850*# for total hard reset (A total hard reset formats /flash0 blowing away everything except CNU.  All settings and personalization of the phone is removed).
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process. This process can take several minutes.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Unfortunately factory reset was not able to make phones register.
I am trying to connect a console to 7970 phone, but phone has a female RJ11 and traditional Cisco console cable has a male RJ45.
Any idea ?
Rosa
Leo Laohoo
1.  Power down the phone.
2.  Hold the # key.
3.  Still holding down the "#" key, power up the phone.
4.  For a 7970G, it takes awhile before the contact buttons start to light up.
5.  Keep holding the "#" down, wait until the contact buttons (those eight flashing buttons on the upper right-hand side) lights up individually) before you hit the "123456789*0#".
This should factory-reset a 7970.
Any idea ?
Rosa
What firmware are you trying to load?
Remember that there is an upgrade path with the 79XX Phone:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/9_1_1/english/release/notes/7900_911.html
Firmware Upgrade Issues for SCCP
Note For  all SCCP firmware upgrades from firmware release versions earlier than  8.3(3) to version 8.5(2)SR1 or greater, you must first upgrade your  firmware to version 8.5(2). Once you have upgraded to version 8.5(2),  you can upgrade your IP Phone to version 9.1(1)SR1 or later.
Note This  section applies to the Cisco Unified IP Phone 7975G, 7971G-GE, 7970G,  7965G, 7962G, 7961G-GE, 7961G, 7945G, 7942G, 7941G-GE, 7941G, 7931G, 7911G, and 7906G.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Jorge I have many 7970G phones.
Only one can not register.
I guess it is a firmware problem.
I would like to connect a console in order to verify if all software is fine, as sugested at
Cisco IP Phone 7970 Administration Guide for Cisco CallManager
Still a problem with the firmware upgrade path, you may try to load 8.5(2) first and see if that makes any difference.
Jorge Armijo
Thanks but, System version: 8.6.2.20000-2 Unrestricted is the curent version.
Even though, there are five more 7970G ip  phones working fine.
I guess there is a specific firmware repair to be done and I do not know how to do it.
Rosa
8.5.2 is phone fimware version, not CUCM software.
Paolo
8.6.2.20000-2 is still phone firmware ?
How can I repair phone firmware?
Copying from other phone firmware  ?
Thanks Rosa
Hi Rosa,
The feature which u are looking for is called Peer Firmware sharing used for upgrading IP phones at remote sites, thereby reducing the load on WAN link.
U need to enable PFS in phone where the firmware is to be upgraded and point to IP address for TFTP to working  7970 phone.
You can try this option else raise the RMA for phone.
regds,
aman
Aman I have a big problem.
I can not access settings on this phone.
I started a factory reset yesterday noon and line buttons still flashes on
Rosa
Hi Rosa,
Raise the RMA if covered in Contract.
regds,
aman
There are many threads on the same subject, use the search funcion.
