Phone count per floor
phifdd4305
I need to get a count of phones per floor per building. I can identify the location by the IP address that each phone is registered to but not sure how to export that using BAT. Any ideas on how to accomplish this?
Chris Deren
The easiest way is to perform a search of the devices in CUCM, if you have more than 250 phones that show up you can edit the URL where it states =250 to something larger, i.e. 3000. Then copy the content of the search and past into Excel as text values. After that you can perform simple sorting based on the IP address column. This works great for these types of jobs.
Jaime Valencia
IP address is not exported in any BAT report as it's only contained in runtime memory, BAT only works with the info contained in the DB, you would need to pull that info (there are plenty of threads on how to get the IPs from CUCM) and then match the info from BAT Vs the IPs.
java
if this helps, please rate
Chris Deren
Awesome! Thanks Chris, I was not aware that you could manipulate the url with a specific number to display. I thought you were bound to the drop down options. This is great!
