Phone Guide URL
rohan_sahi
The end user guide link works when I have
HTTP Status 404 - /PhoneGuides/locales/en_US/PhoneOnlineGuide/6921_41_61/6921sccp.pdf
But doesnt work when US changed to gb
If i change the ling to
HTTP Status 404 - /PhoneGuides/locales/en_gb/PhoneOnlineGuide/6921_41_61/6921sccp.pdf
type: Status report
message: /PhoneGuides/locales/en_gb/PhoneOnlineGuide/6921_41_61/6921sccp.pdf
description: The requested resource (/PhoneGuides/locales/en_gb/PhoneOnlineGuide/6921_41_61/6921sccp.pdf) is not available.
Please suggest how I can change the US to gb.
Thanks in advance.
Rohan Sahi
5 Replies 5
Gajanan Pande
Rohan,
Where are you accessing this URL from ?
If it is from any server, pls ensure you have the folder named " en_gb " under /PhoneGuides/locales/. If it's not, then create one. Further, pls follow the folder path as " /en_gb/PhoneOnlineGuide/6921_41_61/ " & then put " 6921sccp.pdf " there.
Lemme know if I misunderstood your requirement.
If it helps, pls rate the post.
GP.
Hi GP,
Thanks for your suggestion.
But the version of the CUCM is 8.x and the link is to be accessed from the end user desktop.
Please let me know if we need to create the folder on the end user desktop.
Rohan
Rohan,
I am sorry but I am unable to understand what exactly you are trying to do ? Is any Contact Center involved in it ?
also, what is following ?
type: Status report
GP.
Hi GP,
This is for downloading end user guide for the IP phone from the end user login page.
http:///ccmuser
here we get a tab to download a end user guide for the IP Phones.
This is the error that I get when i change the link to GB in the System wise parameters.
type: Status report
Rohan, thanks for the details provided.
I dont think it can be changed & mostly we will have to live with it. BTW, could you share a screenshot of User Login page, which gives a tab to download a end user guide for the IP Phones ?
GP.
