03-01-2016 08:55 AM - edited 03-17-2019 06:05 AM
we have prepared the customers network for a VOIP solution with Avaya-phones.
A few days ago the first test devices came and after connecting them, we have the issue that the MAC is visible in both VLANs and is not timing out.
Everything works fine, but we are planning to implement NAC/802.1x in the next 2-3 months, so I'm afraid that this could be an issue then. Here's the config:
interface GigabitEthernet1/0/48
switchport access vlan 621
switchport mode access
switchport voice vlan 679
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
Phone only:
Vlan Mac Address Type Ports
621 a425.1bc5.2bf6 DYNAMIC Gi1/0/48
679 a425.1bc5.2bf6 DYNAMIC Gi1/0/48
Total Mac Addresses for this criterion: 2
Phone + PC:
621 0023.248d.9c82 DYNAMIC Gi1/0/41
621 f873.a2f4.40a5 DYNAMIC Gi1/0/41
679 f873.a2f4.40a5 DYNAMIC Gi1/0/41
Total Mac Addresses for this criterion: 3
I did some research and found different descriptions for this behavior. As example a statement in an old thread:
“In the older code versions (If I remember it right pre-12.2(44)SE), the switch did not remove the MAC from the data
vlan. Post 12.2(44)SE, they made a change to the code so the switch removes
the MAC from the MAC address table (from data vlan) as soon as the IP Phone
switches to voice vlan. I did see a bug filed for 12.2(50)SE again with the
same symptoms, so not sure if it is completely fixed. But it is not of a big
concern unless you are configuring port-security and trying to tie down the
number of MAC entries per interface.”
Some say that this is normal behavior after booting the phone, but should time out after some time.
A partner company is running 12.2.(55) SE with Avaya-phones and for me, their behavior is "normal":
101 001b.4f15.063d STATIC Gi1/0/1
11 5c26.0a0c.8118 STATIC Gi1/0/1
We have C3650-48FS-L, running IOS XE 3.3.5, so we can't tell, if this issue exists in this firmware also. Release notes don't say anything about known or resolved issues up to 3.6.x
I have read that this has impact on Port-Security, so that you always have to set the max MAC addresses to 3 when connecting IP-Phones.
But I don't know if it will have impact on 802.1x configuration/authentication.
Anyone familiar with a similar case?
BR
03-08-2016 08:28 PM
The phone ports are technically considered trunk ports. ( since the phone serves both data and voice vlans). Trunks mac-address is in each mac-address table for VLANS they serve.
03-09-2016 12:16 AM
thanks for the reply. But why isn't the same behavior occurring at the partner company?
Or on devices of 2 other customers:
1 3464.a90b.ba52 DYNAMIC Gi0/9
44 0004.1331.dbcc DYNAMIC Gi0/9
10 2c59.e500.615c DYNAMIC Gi1/0/30
44 001a.e858.59a1 DYNAMIC Gi1/0/30
The phones are also trunking the connection to the PC, but their MAC is definitely not showing up in both VLANs. So I can't believe that this is the normal behavior - except it is different in IOS XE? Because all other customers have normal IOS.
BR
03-09-2016 06:21 PM
Here is an example from internal documents and i apologize for the format look at the very last line:
07-29-2016 07:41 PM
We have the same issue using Mitel 5330IP phones on Cisco 2960X on 15.2(2)E4 software. IP phones show up in both vlans on some ports, but others show just the voice vlan. Using Port-Security, we have to set the max MAC addresses to 3 as well to resolve this.
We've started deploying 802.1x at sites. With the Mitel phones, as soon as the MAC address of the phone shows up in both vlans, the port shuts down into an err-disabled state. The phones are 802.1x capable, but I haven't had any luck having the them authenticate. From what I've read online, MAB is the only solution, but I have yet to test this.
We have 2 sites that have Cisco IP phones. With these I've read that the phone and switch use CDP and the switch moves the phone into the voice vlan. This works, but every now and then I'll see something weird happen. What happens is the phone shows up in voice vlan and then fails 802.1x authentication and gets moved into the failed authorized vlan and the phone then shows "Phone Registering" on the screen.
Have either of you seen something like this with the Cisco phones?
BR, have you had any luck in your 802.1X deployment?
Jackson
03-28-2019 04:39 AM
We have the same issue with Mitel 6930 IP phones 2690x swithes running Version 15.2(2)E6 and some of the switch port learning the phone MAC in both voice and data vlan.
Do we know the solution please?
Muhammad
11-28-2022 10:38 PM
I am having this same issue with a Cisco 8811. For me the phone is displaying "Verify Network Connection" and is not operational. I have it on DHCP and it pulls an IP, can ping it etc. But it is showing both data and voice vlan in the mac address table like the others.
When the mac-address table is cleared, it will show in our voice vlan for around 30 seconds before showing both vlans for the mac.
Still looking for a fix to this after a week without having to find a workaround.
v/r
Riazi
03-16-2017 02:24 AM
did you find a solution?
thanks
Marco
07-25-2022 05:04 PM
I am experiencing this same issue on my switches. Maybe it is a non-issue?
MAC for the phone shows up in both voice and data VLANs.
1 32 WS-C3850-24U 16.12.05b CAT3K_CAA-UNIVERSALK9 INSTALL
