phone reg issue cme 10.5
mkhriesa
1- 3905 , the status stuck on registration and when we tried to access the setting it asked about passowrd?
2- 7821: stuck on registration , when we press setting we got XML Parse Error[4]
2911 , cme 10.5
we have issue on registration the following:
please advise , attached is sh run
paste these commands (they are listed in previous post)
voice service voip
 sip
  registrar server expires max 60 min 3600
voice register global
no authenticate register
no authenticate realm all
 create profile
7 Replies 7
Nadeem Ahmed
Can you please confirm the firmware version of these phones .
along with that please take below debugs
debug tftp events
debug tftp packets
debug ccsip message
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
what do you see in phone status message ? can you try the below fast track configuration.
reference-pooltype phone-type
voice register pool-type 7821
description Cisco IP Phone 7821 reference-pooltype 6921
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#wp1291314
https://supportforums.cisco.com/discussion/12379911/cme-sip-issue-cisco-7821-phone-not-registering
regards,
-Do rate helpful posts.
Hi, FYI CME 10.5 supports phone type 78XX and won't need fast track. It won't allow to create
Are you phones in the same LAN of the CME? If yes then remove then apply these commands and restart the phones
voice service voip
 sip
 create profile
If the phones are in remote LAN, then apply these commands and restart the phones
voice service voip
 sip
voice register pool  1
username phone1 password phone1
voice register pool  2
username phone2 password phone2
voice register pool  3
username phone3 password phone3
create profile
dear,
its on the same vlan, what i should remove?
voice service voip
 sip
 create profile
mkhriesa
THnaks SOLVED :)
