Phone registers but won't pull a DN
riedmueller
Hello
I have been trying to troubleshoot this for a while, and can not figure out what I need to do to fix it.
Cisco 2811 running CME 7.1 with two 7960G phones. One is completely operational, the other registers but does not pull a DN.
Some snippets from the Router's configuration:
Telephone Service Parameters
pod12rtr#sho telephony-service
CONFIG (Version=7.1)
Version 7.1
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
ip source-address 192.168.108.193 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
load 7960-7940 P00308000500
load 7961 SCCP41.8-4-2S
load 7971 SCCP41.8-4-2S
max-ephones 5
max-dn 10
TFTP Server Configuration (just the firmware part)
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sb2
tftp-server flash:P00308000500.sbn
tftp-server flash:apps41.8-4-1-23.sbn
tftp-server flash:cnu41.8-4-1-23.sbn
tftp-server flash:cvm41sccp.8-4-1-23.sbn
tftp-server flash:dsp41.8-4-1-23.sbn
tftp-server flash:jar41sccp.8-4-1-23.sbn
tftp-server flash:SCCP41.8-4-2S.loads
tftp-server flash:term41.default.loads
Ephone Configurations
pod12rtr#sho run | b ephone-dn
ephone-dn  1  dual-line
number 1281
name P12Voip1
ephone-dn  2  dual-line
number 1280
name P12Voip2
ephone  1
device-security-mode none
mac-address 0018.B995.0187
type 7960
button  1:1
ephone  2
mac-address 0018.B935.BBAA
type 7960
button  1:2
Output of DEBUG EPHONE REGISTER (I dropped power and then re-applied)
pod12rtr#
Sep 25 05:40:15.535: New Skinny socket accepted [2] from 0, sub 1 (2 active)
Sep 25 05:40:15.535: sin_family 2, sin_port 49869, in_addr 192.168.108.194
Sep 25 05:40:15.535: skinny_add_socket 2 192.168.108.194 49869
Sep 25 05:40:15.539: %IPPHONE-6-REG_ALARM: 25: Name=SEP0018B9550187 Load=8.0(5.0) Last=Initialized
Skinny StationAlarmMessage on socket [2] 192.168.108.194 SEP0018B9550187
Sep 25 05:40:15.539: severityInformational p1=2304 [0x900] p2=-1033066304 [0xC26CA8C0]
Sep 25 05:40:15.539: 25: Name=SEP0018B9550187 Load=8.0(5.0) Last=Initialized
Sep 25 05:40:15.539: ephone-(3)[2] StationRegisterMessage (2/2/6) from 192.168.108.194
Sep 25 05:40:15.539: ephone-(3)[2] Register StationIdentifier DeviceName SEP0018B9550187
Sep 25 05:40:15.539: ephone-(3)[2] StationIdentifier Instance 1    deviceType 7
Sep 25 05:40:15.539: ephone-3[2/1]:stationIpAddr 192.168.108.194
Sep 25 05:40:15.539: ephone-3[2/1][SEP0018B9550187]:maxStreams 0
pod12rtr#ne-3[2/1][SEP0018B9550187]:From Phone raw protocol Ver 0x8560000B
Sep 25 05:40:15.539: ephone-3[2/1][SEP0018B9550187]:protocol Ver 0x8560000B
Sep 25 05:40:15.539: ephone-3[2/1][SEP0018B9550187]:phone-size 23664 dn-size 816
Sep 25 05:40:15.539: ephone-(3) Allow any Skinny Server IP address 192.168.108.193
Sep 25 05:40:15.539: ephone-3[2/1][SEP0018B9550187]:Found entry 2 for 0018B9550187
Sep 25 05:40:15.539: ephone-3[2/1][SEP0018B9550187]:socket change 1 to 2
Sep 25 05:40:15.539: ephone-3[2/1][SEP0018B9550187]:DisAssociate: Closed socket 1 while REGISTERED
Sep 25 05:40:15.543: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-3:SEP0018B9550187 IP:192.168.108.194 Socket:1 DeviceType:Phone has unregistered abnormally.
Sep 25 05:40:15.543: ephone-3[2/-1][SEP0018B9550187]:FAILED: CLOSED old socket -1
Sep 25 05:40:15.543: ephone-3[2/2][SEP0018B9550187]:***Force device subtype to 0
Sep 25 05:40:15.543: ephone-3[2/2][SEP0018B9550187]:phone SEP0018B9550187 re-associate OK on socket [2]
Sep 25 05:40:15.543: %IPPHONE-6-REGISTER_NEW: ephone-3:SEP0018B9550187 IP:192.168.108.194 Socket:2 DeviceType:Phone has registered.
Sep 25 05:40:15.543: Phone 2 socket 2
Sep 25 05:40:15.543: Skinny Local IP address = 192.168.108.193 on port 2000
Sep 25 05:40:15.543: Skinny Phone IP address = 192.168.108.194 49869
Sep 25 05:40:15.543: Update tftp binding for SEP0018B9550187
Sep 25 05:40:15.543: ephone-3[2/2][SEP0018B9550187]:Signal protocol ver 12 to phone with ver 11
Sep 25 05:40:15.543: ephone-3[2/2][SEP0018B9550187]:Date Format M/D/Y
Sep 25 05:40:15.543: ephone-3[2/2]:RegisterAck sent to sockettype ephone socket 2: keepalive period 30 use sccp-version 9
Sep 25 05:40:15.543: ephone-3[2/2]:CapabilitiesReq sent
Sep 25 05:40:15.551: ephone-3[2/2]:HeadsetStatusMessage
Sep 25 05:40:15.587: ephone-3[2/2]:MediaPathCapabilitiesMessage
Sep 25 05:40:15.587: ephone-3[2/2]:MediaPathEventMessage
Sep 25 05:40:15.591: ephone-3[2/2]:MediaPathCapabilitiesMessage
Sep 25 05:40:15.591: ephone-3[2/2]:MediaPathEventMessage
Sep 25 05:40:15.595: ephone-3[2/2]:CapabilitiesRes received
Sep 25 05:40:15.595: ephone-3[2/2][SEP0018B9550187]:Caps list 8
WideBand_256K  120 ms, is_mtp 0
G711Ulaw64k  40 ms, is_mtp 0
G711Alaw64k  40 ms, is_mtp 0
G729AnnexB  60 ms, is_mtp 0
G729AnnexAwAnnexB  60 ms, is_mtp 0
G729  60 ms, is_mtp 0
G729AnnexA  60 ms, is_mtp 0
Unrecognized Media Type 257  4 ms, is_mtp 0
Sep 25 05:40:15.599: ephone-3[2/2]:MediaPathEventMessage
Sep 25 05:40:15.751: ephone-3[2/2]:MediaPathEventMessage
Sep 25 05:40:15.751: ephone-3[2/2]:ButtonTemplateReqMessage
Sep 25 05:40:15.751: ephone-3[2/2][SEP0018B9550187]:StationButtonTemplateReqMessage set max presentation to 6
Sep 25 05:40:15.751: ephone-3[2/2]:CheckAutoReg
Sep 25 05:40:15.751: ephone-3[2/2]:AutoReg is disabled
Sep 25 05:40:15.751: ephone-3[2/2][SEP0018B9550187]:Setting 6 lines 0 speed-dials on phone (max_line 6)
Sep 25 05:40:15.751: ephone-3[2/2][SEP0018B9550187]:First Speed Dial Button location is 0 (0)
Sep 25 05:40:15.751: ephone-3[2/2]:ButtonTemplate lines=6 speed=0 buttons=6 offset=0
Sep 25 05:40:15.751: ephone-3[2/2][SEP0018B9550187]:ButtonTemplate buttonCount=6 totalButtonCount=6 buttonOffset=0
Sep 25 05:40:15.751: ephone-3[2/2][SEP0018B9550187]:Configured 0 speed dial buttons
Sep 25 05:40:15.759: ephone-3[2/2]:StationSoftKeyTemplateReqMessage
Sep 25 05:40:15.759: ephone-3[2/2]:StationSoftKeyTemplateResMessage
Sep 25 05:40:15.767: ephone-3[2/2]:StationSoftKeySetReqMessage
Sep 25 05:40:15.767: ephone-3[2/2]:StationSoftKeySetResMessage
Sep 25 05:40:15.787: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 6
Sep 25 05:40:15.787: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 6 Invalid DN -1
Sep 25 05:40:15.787: ephone-3[2/2][SEP0018B9550187]:StationLineStatResMessage sent to ephone (1 of 6)
Sep 25 05:40:15.791: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 5
Sep 25 05:40:15.791: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 5 Invalid DN -1
Sep 25 05:40:15.791: ephone-3[2/2][SEP0018B9550187]:StationLineStatResMessage sent to ephone (2 of 6)
Sep 25 05:40:15.799: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 4
Sep 25 05:40:15.799: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 4 Invalid DN -1
Sep 25 05:40:15.799: ephone-3[2/2][SEP0018B9550187]:StationLineStatResMessage sent to ephone (3 of 6)
Sep 25 05:40:15.807: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 3
Sep 25 05:40:15.807: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 3 Invalid DN -1
Sep 25 05:40:15.807: ephone-3[2/2][SEP0018B9550187]:StationLineStatResMessage sent to ephone (4 of 6)
Sep 25 05:40:15.815: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 2
Sep 25 05:40:15.815: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 2 Invalid DN -1
Sep 25 05:40:15.815: ephone-3[2/2][SEP0018B9550187]:StationLineStatResMessage sent to ephone (5 of 6)
Sep 25 05:40:15.823: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 1
Sep 25 05:40:15.823: ephone-3[2/2]:CheckAutoReg
Sep 25 05:40:15.823: ephone-3[2/2]:AutoReg is disabled
Sep 25 05:40:15.823: ephone-3[2/2][SEP0018B9550187]:StationLineStatReqMessage from ephone line 1 Invalid DN -1
Sep 25 05:40:15.823: ephone-3[2/2][SEP0018B9550187]:StationLineStatResMessage sent to ephone (6 of 6)
Sep 25 05:40:15.823: ephone-3[2/2]:SkinnyCompleteRegistration
Sep 25 05:40:15.895: ephone-3[2/2][SEP0018B9550187]:Skinny Available Lines 6 set for socket [2]
Sep 25 05:40:15.895: ephone-3[2/2]:Already done SkinnyCompleteRegistration
pod12rtr#
Output of SHOW EPHONE PHONE-LOAD
pod12rtr#sho ephone phone-load
DeviceName        CurrentPhoneload       PreviousPhoneload      LastReset
SEP0018B9550187   8.0(5.0)               8.0(5.0)               Initialized
SEP0018B935BBAA   8.0(5.0)               8.0(5.0)               Reset-Restart
pod12rtr#
Can anyone help me in the right direction here?
Rob Huffman
Hi Reid,
It looks to me like the ephone mac address may have been
set incorrectly.
But in the traces we see;
SEP0018B9550187
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
Rob Huffman
Hi Reid,
set incorrectly.
SEP0018B9550187
Cheers!
Rob
How embarassing
Thanks for picking up on that. Changed the MAC and reset the phone and it's working fine.
Maybe I need to get my eyes checked
Rob Huffman
Hey Reid,
Don't be embarassed my friend If I had a nickle
for every time I've missed something like this I'd be
a rich man That's why an extra set of eyes is so
helpful here.
Cheers!
Rob
