03-02-2011 12:54 PM - edited 03-16-2019 03:44 AM
Situation:
7960 and 6961 devices.
Location has multiple shared lines across all devices. 7960 allow up to 6 calls and 6961 has 12 line configured. When a call is in the "Connected" state the softkey template is configured to offer Hold, End Call, Transfer and More softkeys. When a second inbound call comes into the shared line the device defaults to hightlight the new call and changes the softkeys to the "Ring In" state. This is causing confusion to the users despite being told to use the rocker button to hightlight the active call again.
Is there a way to change the behavior on the device to not hightlight the new incoming call? If so, is it possible to do this on a per phone basis or is it a service parameter only feature?
Thank you for your time,
Melissa
03-03-2011 05:31 AM
Hi Melissa,
Try changing the System setting Auto-Call Select. With this Enabled the Display Focus (and Softkeys) always switch to the new incoming call. So if disabled the focus and Softkeys will stay on Call #1.
Also available on an individual phone via this setting
Device>Phone>Phone Configuration>Product Specific Configuration>Auto Call Select>Disabled
Cheers!
Rob
03-03-2011 08:09 AM
Thank you, Rob!
Unfortunately this is not a configurable parameter on the 6900 series and second generation 7940/60 devices. I have a TAC case open currently to find out the future availablity of this option on the 6900 series.
This solution is working for my third generation devices (41/61)
Melissa
09-13-2012 09:15 AM
Do you know of any way to acheive this on CME. I'm having the same issue for a client using CUCME and haven't had a lot of luck fixing this
09-24-2012 02:40 PM
Rob,
I've witnessed a similar but slightly different situation with a client running CUCM 8.5(x). One of the users has several shared lines on her phone. When she's on a call and a second call comes in on the same active line, it stacks below the first and changes the Softkey layout from "Connected" to "Ring In" as Melissa described. When a second call rings in on a different line, that call stays hidden behind the call information of the existing call. This is very troublesome for the user in question as she can't judge the importance of the inbound called based on calling party ID.
If the line button of the active call (which is solid green) is tapped, it hides the existing call information and Softkeys as usual but does not reveal the inbound call information of the second call. (If I recall correctly) if the line button of the ringing line is tapped it answers the ringing call and automatically puts the first call on hold before allowing the user/operator to see who's calling.
Is there a parameter which will allow all inbound calls from multiple line appearances to "stack" as if they were all coming in on a single line appearance so the operator can see the inbound caller ID of all new calls?
Phil
09-25-2012 05:42 AM
Hi Phil,
It sounds to me like you would need to enable "Auto Line Select"
as well
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
09-25-2012 10:02 AM
Thanks, Rob! I'm going to come out of this engagement looking like a rockstar thanks to these finds. What doc did you pull them from? CUCM admin guide?
Phil
09-25-2012 10:05 AM
Hi Phil,
You are most welcome my friend
I always thought these field descriptions would come from a CUCM
guide.... but they actually came from a phone/admin guide
Cheers!
Rob
09-25-2012 10:11 AM
Ok, I just thought of another question. If we leave "Auto Line Select" disabled is there a way to manually shift focus from the current call to the inbound call on the second line? The receptionists I'm working with are weirded out enough by "losing their buttons" as it is with the "Auto Call Select" being enabled. Is there some way to manually toggle between lines to see inbound calls BEFORE answering and without losing the current call?
I found this in the 79xx user guide but it doesn't mention anything about viewing the ringing call (to figure out who's calling!) - only switching to it.
If you can find an answer you can kill two birds with one stone
