12-13-2019 11:08 AM - edited 12-13-2019 11:23 AM
Hi all,
I have cisco 3905, every time I reboot the phones they don't register, they stay in the "loading" I have to manually reboot the phone to make it register.
thanks.
12-14-2019 03:42 PM
What do you see in the status messages on the phone and in the console log of the phone?
12-16-2019 03:35 AM
I only see on the phone loading, If I reboot the phone manually I connect with no issue.
thanks.
12-16-2019 05:34 AM
If you browse the IP address of the phone and pull the console logs what do you observe?
12-16-2019 05:59 AM
I can't access the console web page, because they are not registered.
thanks.
12-16-2019 06:42 AM
Phone does not need to be registered to access it's website. What do you get when you enter the IP address of the phone in a web browser?
12-16-2019 06:54 AM
12-16-2019 07:31 AM
In CUCM Admin, do you have "Web Access" enabled on phone configuration page. If not enable it and then download the log files. (The settings will take effect only when the phone is registered with CUCM.)
12-16-2019 07:38 AM
I am assuming since it's stuck in loading you will not be able to change the "web access" in CUCM. Just wondering can you actually ping the IP address of the phone? Is it even routable on your network?
12-16-2019 07:41 AM
In the initial post, he mentioned that he manually reboots the phone to make it register.
12-16-2019 09:10 AM
Hello Vaijanath
Yes if I manually reboot the phone it will get registered, the idea is to know why this is happening.
thanks.
12-16-2019 11:33 AM
Once the phone is registered, can you download the logs from web interface and upload it to here.
12-17-2019 04:27 AM
Hi all,
I was checking the config , and saw that the issue is on phone that are not in the same IP range as the cucm.
Thanks.
12-16-2019 09:04 AM
Hello ,
Yes I can ping the phone from the cucm.
thanks.
