phones lost connection
Austin3:16
I've noticed that some IP phones, specifically the 3905 model, enter "configuring IP" mode. Upon diagnosing the issue, I observed that these IP phones lose their IP addresses from the DHCP server. Even when configured in static mode, the problem is temporarily resolved, but after a few days, the phones lose their IP addresses again. The phone in static mode also becomes unpingable. I performed an upgrade to the latest version, but the issue persists after a few days.
and I noticed some port instability on the switch.
I noticed this behavior in the past but it was not a DHCP issue. It was a bug with CDP messages received by the phone that was interpreted as port reconfiguration message.
Try to statically define the Voice Vlan on the phone and disable CDP on the switch interface.
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
13 Replies 13
Leo Laohoo
How long is the DHCP lease?
8 days but the problem with static ip too
Can you elaborate the meaning of "static IP"?  Did you manually assign an IP address to the phone or did you put a MAC address reservation against an IP address?
Bring the lease down to 8 hours and see if it makes a difference.
You note switch port instability. I can see that impacting the phones. I assume you are taking steps to diagnose and resolve that issue.
Do the phones come back if you power-cycle the port?
Maren
yes
Please let me know
Carlo
Ok i will let you know if the problem percist.
I have concerns about the Switches 2960  can upgrading the firmware resolve the issue since they have an old firmware
yes you are right and its solve my problem
It depends on what model of 2960 you have.
Some of them went in EoL ages ago and firmware is no longer available on Cisco Software Manager.
Let me know
Carlo
Yes know, they have E6 firmware i will try to E9 its the last version
before upgrading the firmware, please try what I suggested to verify if the issue solves with this configuration
Carlo
 If I disable CDP, will there be any impact on Cisco access points?
Technically it doesn’t have any impact on AP but you don’t need to disable it globally but on single interface where 3905 are connected to.
Let me know
Cheers
Carlo
