05-10-2011 10:22 AM - edited 03-16-2019 04:54 AM
I have the following deployment:
CUCMBE 8.5, CCM-Manager 7.1, 2921 voice gateway (IOS c2900-universalk9-mz.SPA.150-1.M4.bin), Phone load SCCP45.8-5-4S
All phones register to CUCMBE just fine but when I test my SRST gateway, the phones do register but the extensions do not associate with a DN. Its a pretty common problem but I made sure all the versions and loads and IOS are compatible for this feature. I have no clue why my phones do not get a DN when they fallback to SRST. Here're the necessary configs:
<<output omitted>>
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.97.22.252
ccm-manager config
mgcp
mgcp call-agent 10.97.22.252 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
<<output omitted>>
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 8
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.97.22.254 port 2000
max-ephones 100
max-dn 150
system message primary CallManager Unavailable
dialplan-pattern 1 8[2-9]......... extension-length 10
keepalive 10
time-zone 5
Does anyone know what could be a workaround for this? I am considering going ahead with the 15.0(1)XA IOS for my 2921 voice gateway. I will post an update on what I observe after the IOS upgrade.
Thanks for taking some time out and looking at this. Appreciate all the help and assistance.
05-10-2011 10:54 AM
I have run into this issue before and it has to do with the phone loads and SRST version. It was a conflict with the button template. I was running 7.1 on the router and needed to use 8.4.1 to get it going correctly. I think for CME 8.5 the recommended phone load is 9.1.
- Jason
05-10-2011 12:57 PM
Downgrading the Phone-Load to SCCP45.8-3-3SR2S worked for me. I always knew it was a Phone-Load issue after looking at similar discussions on the Internet. I tried 8.5.4. and 8.4 and 9.1 and 9.0, it was just a matter of finding the right load. Thanks Jason!
05-10-2011 05:24 PM
I agree with others here, it's typically a phone load or IOS compatibility.
Chris
05-10-2011 05:39 PM
Geez now my phone-load is legacy and won't sow the correct time. Instead of using the local NTP time from the voice gateway, it shows the UTC time.
05-10-2011 06:12 PM
Ok it was an issue with the legacy phone-load. Phone-Loads 9.0(2) and prior require you to select a compatible time zone (marked with 2 '+' signs one on top of other) on the Call Manager NTP reference list.
