02-24-2008 02:24 AM - edited 03-15-2019 09:02 AM
please help me clarifying how to use pin code to allows individual phone users to override call-blocking patterns that are associated with defined time periods.
I read that An individual with a PIN can override call blocking by entering the PIN after pressing the Login soft key to log in to a phone that has been configured for that PIN using the pin command. but I'm trying to press Login softkey (status: on hook) but it says: that key is not active here
please advise
thanks
02-24-2008 06:08 AM
Hi UC,
Maybe you are seeing this Restriction;
Note that logging in to a phone with a PIN only allows the user to override call blocking that is associated with particular time periods. ***Blocking patterns that are created with the 7-24 keyword in the after-hours block pattern command are in effect 7 days a week, 24 hours a day, and they cannot be overridden by using a PIN.
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html
Hope this helps!
Rob
02-24-2008 09:03 AM
Hi Rob,
no, I already know this and undertand the concept well, but what I ask about may be a silly question i just want to know how to use this feature on IP phone
i have dial-peer voice with after-hour block pattern but not 7-24 and i configured pin 12345 under ephone and restarted that phone but when i go to that phone (status: on hook) and press the Login softkey to enter the pin it says : this key is not active here!
so am I correct in the way i'm using pin, if so then what's wrong with that softkey?!
thanks
07-30-2008 10:04 PM
hey,
im running into the same problem, login softkey not active here message.
the solution is to create new softkey template.
08-18-2009 11:37 AM
My "Login" softkey is Gray and says "That key is not active here" when I press it. I created a new template, and moved the "login" key to the first key in idle mode.
The ephone has a pin, and is currently being blocked from making long distance calls, but not with the 7-24 command. I'm just saying that I'm in the time window that restricts long distance.
So what would cause the Login softkey to be grayed out?
EDIT: Nevermind - I found it. I was missing the login timeout settings.
I used:
telephony-services
login timeout 60 clear 17:00
02-24-2008 09:48 AM
Hi UC,
Sorry about that :) Remember there is no such thing as a silly question. Yes, the method of Pressing the Login Softkey with the IP Phone in the Idle state is the correct method for entering the PIN code.
Hope this helps!
Rob
05-07-2009 12:11 AM
Hi all,
facing same problem here.
need help plz .
08-18-2009 01:37 PM
Please open new thread for new problems, describe the issue in detail, include all relevant configuration.
