PLAR on VG224
aeriksson
Hi!
Does any one has a sample config for PLAR on a VG224?
I have followed this guide,but suspect I need some config in the VG as well,
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml#Steps1
5 Replies 5
Aaron Harrison
Are you running H.323 or MGCP on your VG?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi! It is H323. regards Annika
THe document you saw really refers to MGCP, where all the dial plan stuff is controlled by CCM.
As you are H.323, you need to enter this command on the voice-port :
connection plar xxxx
Where xxxx is the number you want to dial.
Aaron
Please rate helpful posts...
Sorry I was totally wrong. The VG224 is set up in SCCP-mode. Not H323 as I wrote before.
No additional configuration needs to be performed on the VG224 assuming the VG224 is working properly otherwise.
If you follow the Cisco instructions and are having issues, you may need to add the partition of the destination DN to the calling search space, not just the newly created autodial partition.
Hope that helps.
