POTS dial-peer trying to register with SIP Registrar
nz78au
Hi All,
I was setting up CUBE-SIP-to-SIP trunk for PSTN. This router is also set up for SRST and it has relevant dial-peers configured. After configuring this I saw following messages trying to send the register messages to registrar:as.nipt.telstra.com. The service provider saw those message as well. To stop this initially I shut down all the dial-peers and later I had to add "no sip-register" and after no shut I can see those messages have stopped. I am now wondering why this happened? Why these dial-peers were sending the messages? Is adding "no sip-register" a solution or just a work around.
Nov  8 16:36:58.242 ACST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:as.nipt.telstra.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.20.251.45:5060;branch=z9hG4bK5414D2
From: <sip:004........@as.nipt.telstra.com>;tag=4633F78-67F
To: <sip:004........@as.nipt.telstra.com>
Date: Tue, 08 Nov 2011 07:06:58 GMT
Call-ID: C21A9B6D-8E911E1-811C9CC9-B72173B1
User-Agent: Cisco-SIPGateway/IOS-15.2(1)T1,
Max-Forwards: 70
Timestamp: 1320736018
CSeq: 91 REGISTER
Contact: <sip:004........@10.20.251.45:5060>
Expires:  3600
Supported: path
Content-Length: 0
18 Replies 18
Thanks Roger - I have 2 user defined pots dial peers (4000 & 4001) and I added the "no sip-register" command on them, but for some reason I still see them when running "sh sip register status":
Tenant: 1
--------------------- Registrar-Index 1 ---------------------
Line peer expires(sec) reg survival P-Associ-URI
1234567890LP -1 149 yes normal
Tenant: 1
^9* 4000 57 no normal
Tenant: 1
^[3-9]11 4001 94 no normal
And my provider is saying they are still seeing invalid register attempts... did I miss something?
Not from what I know. What version of IOS are you using? If it’s a really old one you might want to consider an update.
Response Signature
ciscosmbrt14
Thanks Roger - we're using version 16.09.05, it's a little older but not super old.  It's strange though as the pots dial-peers do accept the "no sip-register" command, but still are showing when running "sh sip register status".  It doesn't seem to be causing any problems - just that the provider is receiving invalid register attempts, was hoping to prevent it to avoid confusion in any future troubleshooting..
Still a quite old one, at least when it comes to the release train. I would advice you to go to something more current, like 17.6.4.
Response Signature
