POTS (FXO) Translation to an Internal Extension?
I have a POTS line on an FXO port (0/1/0) and want to have inbound calls to that number ring on ext 360. I will eventually have a PRI as well. In the end all calls will ring on the operator extension (testing using 360) ... company is old fashion, no AA.
I know I can "tie" the FXO to the phone via a "plar" to 360 (had it running that way), but I wanted to set things up like I believe I will have to for the PRI with DIDs getting installed in a few weeks. Therefore, I wanted to use "voice translation-profiles" for mapping inbound calls to the FXO (in prep for the new PRI) to the operator (x-360).
FYI - Since the POTS does not have DID, the "called" number is blank (aka - OriginalCalledNumber in the "show" output).
So I put in the config:
voice translation-rule 200
rule 1 /^\(.......\)$/ /8\1/
rule 2 /^\(..........\)$/ /8\1/
voice translation-rule 210
rule 1 /.*/ /360/
voice translation-profile Redirect-To-Operator
translate called 210
voice-port 0/1/0
translation-profile incoming Redirect-To-Operator
description Rockford, POTS 1, E911 Backup 1
caller-id enable
dial-peer voice 10 pots
description Incoming POTS-1
incoming called-number .*
port 0/1/0
ephone-dn 38 dual-line
number 360
pickup-group 34
label Sample User (360)
description Materials
name Sample User
call-forward busy 200
call-forward noan 200 timeout 10
corlist incoming User-LongDist
hold-alert 30 idle
ephone 38
description Sample User - 7962G - MAC:0021A0D98F08
mac-address 0021.A0D9.8F08
ephone-template 1
emergency response location 1
type 7962
button 1:38
When I call in, it picks up, then disconnects me without ringing the IP phone. If I look at the debug and show commands, I see it translates correctly (show call leg history):
Call Information - Connection ID: 128D , Call Leg ID: 34
GENERIC:
SetupTime=92358270 ms
Index=52
PeerAddress=1112223333 <--I changed
PeerSubAddress=
PeerId=20
PeerIfIndex=77
LogicalIfIndex=6
DisconnectCause=10
DisconnectText=normal call clearing (16)
ConnectTime=0 ms
DisconnectTime=92361370 ms
CallDuration=00:00:00 sec
CallOrigin=2
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0xEE6B9A70 0xF8B411DD 0x80B0BCB9 0x827F8056]
IncomingConnectionId=[0xEE6B9A70 0xF8B411DD 0x80B0BCB9 0x827F8056]
CallID=52
Port=0/1/0 (52)
BearerChannel=0/1/0
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=USER, JOE <---I Changed
CallerIDBlocked=False
LongDurationCallDetected=no
LongDurCallTimeStamp=
LongDurCallDuration=
OriginalCallingNumber=1112223333 <---I Changed
OriginalCallingOctet=0x0
OriginalCalledNumber= <<<<<<NO GOOD
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=1112223333 <---I Changed
TranslatedCallingOctet=0x0
TranslatedCalledNumber=360 <<<<<<<<GOOD
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwReceivedCallingNumber=1112223333 <---I Changed
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x0
DSPIdentifier=0/1:1
Total call-legs: 2
It appears that the called number gets changed to 360. But 360 doesn't ring (I can ring 360 internally and call out on 360 fine). What am I doing wrong?
FYI - I see it matching the incoming dial-peer of:
r1-rtr-voip#debug voice dialpeer
Feb 13 03:46:17.404: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=1112223333, Called Number=360, Voice-Interface=0x47D551BC,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=10
Help?
6 Replies 6
Hi Chris,
I think this is an artifact of the way that connection plar works on FXO ports. It appears that the call-control API (CCAPI) does not kick the call off right, because translating an incoming called number of "" is different than a plar statement. This can be highlighted by the fact that there is both a 'connection plar' and 'connection plar opx' which are two different call routing processes. The default behavior if there isn't a connection plar statement is to play dial tone for two-stage dialing, and it appears that the translation pattern is interfering with that.
Your translation pattern looks fine, and this should work when you have your PRI installed.
I generally prefer to put my "translation-profile incoming Redirect-To-Operator" statement under the dial peer, because I normally don't look for call routing statements under the voice port. You may try putting this on dial peer 10 and see if you have different results.
Hope this clarifies a bit.
-nick
Having the translation profile on the matching dial-peer is how I had it originally, but that did not work.
Here is what happened...
1) moved translation from voice port to dial-peer.
voice-port 0/1/0
caller-id enable
port 0/1/0
2) Made call in, monitoring the dial-peer (confirm match to dial-peer I thought it would and the one I applied translation to):
r1-rtr-voip#
Feb 13 15:38:41.389: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=7083499940, Called Number=, Voice-Interface=0x47D551BC,
r1-rtr-voip#
4) Router picked up, and then dropped call. Looking at the call leg history ...
Call Information - Connection ID: 129D , Call Leg ID: 38
GENERIC:
SetupTime=136291920 ms
Index=56
PeerAddress=1112223333 <-- I Changed it
PeerSubAddress=
PeerId=10
PeerIfIndex=75
LogicalIfIndex=6
DisconnectCause=10
ConnectTime=0 ms
DisconnectTime=136297680 ms
CallOrigin=2
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0x396E2125 0xF91B11DD 0x80C0BCB9 0x827F8056]
IncomingConnectionId=[0x396E2125 0xF91B11DD 0x80C0BCB9 0x827F8056]
CallID=56
Port=0/1/0 (56)
BearerChannel=0/1/0
TxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=USER, JOE <--- I changed it
OriginalCallingNumber=1112223333 <-- I Changed it
OriginalCalledNumber= <<<<<<<<<< NOT GOOD!
TranslatedCallingNumber=1112223333 <-- I Changed it
TranslatedCalledNumber= <<<<<<<<<< STILL NOT GOOD???
GwReceivedCallingNumber=1112223333 <-- I Changed it
DSPIdentifier=0/1:1
Total call-legs: 2
r1-rtr-voip#
4) So the translation pattern did not work. I just don't get it.
Are you saying this won't work this way at all with this setup (route FXO via translation pattern)?
Could it be a bug (I am using the latest CME running on "(C2800NM-SPSERVICESK9-M), 12.4(22)T / CME 7.0(1)". Should I be running something else?
Does anyone have some example configs of translation profiles and PRI's that I could model mine after?
Hi, try
rule 1 // /360/
No that did not make a difference. Still matched the 10 dial-peer and still did not translate.
The only way so far I can get this to work is:
1) Setup a "intermediate" dial-peer with the translation to the operator on it:
dial-peer voice 2300 pots
description Intermediate Dial-Peer to Operator
destination-pattern 2300
2) Plar to the intermediate dial-peer:
voice-port 0/1/0
connection plar 2300
caller-id enable
This seems to work and lets me use translation patterns on the incoming and outgoing numbers prior to presentation to the IP phone.
I just don't understand why the other why doesn't work still. I guess I will ask for other examples of a PRI config to see what I need to do when that arrives.
The thing that needs to be understood about the call flow is that connection plar is much more than a translation. By having that command under the voice port, it changes the way to port acts with other parts of software. Doing a simple translation on the calling number is not the same thing, and I would not have any expectation for this to work.
This would not be a bug, because it's fairly flagrant mis-configuration.
-nick
