presence redundancy group configuration in cucm
Sonam
I found this issue and not able to add new user  to imp.. what would cause this ? and how to resolve it?
8 Replies 8
Ratheesh Kumar
Hi there
Could you check the HA status on IM & Presence server ?
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Hi Rath,
Thank you for your respond.
Can you tell me how to check HA status on IM and Presence server?
Thank you
Hi Rath,
it is found to be normal. HA status on im and presence is normal?
how do I solve this issue?
Hi there
Just wondering are you hitting this ?
IM&P - Presence viewer unable to retrieve presence from sub
CSCuz03027
Description
Symptom:
When attempting to view the presence using the Presence Viewer for a CUCM end user who exists on an IM&P subscriber, the following error is displayed:
"Error occurred while retrieving presence information from IM and Presence Server"
This error is not seen when getting the presence of users who exist on the IM&P publisher node.
Conditions:
IM&P 10.5.2SU2
IM&P Cluster with acceptable network delay
Hope this helps!
Cheers
Rath!
Hi Rath,
error " Error retrieving HA status information from the IM and Presence Server"
in both the server I cannot see any assigned , active users and server State, Reason are all blank.( presence redundancy group configuration in cucm) cucm is 11.5
Hi Rath,
on imp server I can see this. attached pic
Please comment
Hi there
Seems to be the nodes are not happy. Would you mind restarting the primary and secondary and see that helps?
Hope this helps!
Cheers
Rath!
Hi there
You can login to Presence and check Presence Topology. Verify the node status under DefaultCupsCluster.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-im-presence-service/200958-IM-and-Presence-Server-High-Availability.html
Hope this helps!
Cheers
Rath!
