03-24-2015 01:39 AM - edited 03-17-2019 02:25 AM
Hello Community,
We plan to have two PRI circuits on our gateway that will have two DID ranges (let say 111-1XXX for 1st PRI and 222-2XXX for 2nd PRI). These PRIs will be on same Provider.
If the 222-2XXX extension call uses the 1st PRI, can the Provider show 222-2XXX as caller ID?
If the 1st PRI is down, can the Provider route the call for 111-1XXX using the 2nd PRI?
Thanks in advance.
03-24-2015 01:47 AM
Contact your service provide.They can configure the hunt from there side.
03-24-2015 01:56 AM
Thanks Saif, we are checking with our Service Provider... but would like to know if this generally can be implemented by the ISDN providers.
03-24-2015 02:06 AM
Most Welcome Ramon.
Yes it can be done easily.
regards,
Saif
