PRI Circuits DID Range
Hello Community,
We plan to have two PRI circuits on our gateway that will have two DID ranges (let say 111-1XXX for 1st PRI and 222-2XXX for 2nd PRI). These PRIs will be on same Provider.
If the 222-2XXX extension call uses the 1st PRI, can the Provider show 222-2XXX as caller ID?
If the 1st PRI is down, can the Provider route the call for 111-1XXX using the 2nd PRI?
Thanks in advance.
SAIFUDEEN C .K
Contact your service provide.They can configure the hunt from there side.
Thanks Saif, we are checking with our Service Provider... but would like to know if this generally can be implemented by the ISDN providers.
Most Welcome Ramon.
Yes it can be done easily.
regards,
Saif
