11-19-2015 01:29 AM - edited 03-17-2019 04:57 AM
Hi all,
I want to choose a primary access card for Cisco router 2911, it should support up to 32 telephony line.what i should choose?
11-19-2015 02:04 AM
Hi Moussa,
Manish
- Do rate helpful posts -
11-19-2015 02:09 AM
Please note that one channel on a T1 or E1 is a D-channel which does not take calls, hence a single PVDM3-32 will not work if you are using T1/E1.
Manish
11-19-2015 02:20 AM
Thank you Manish,
I want to use channel on a E1, what is the interface EHWIC reference i should use?
regards,
11-19-2015 02:36 AM
what i mean is EHWIC Interface card, can i use this one HWIC-1CE1T1-PRIN ?
11-19-2015 02:42 AM
HWIC-1CE1T1-PRI does work with 2911 as per the following
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/network-modules/product_data_sheet0900aecd80710c88.html
www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
Manish
11-19-2015 02:55 AM
okey Manish,
in router 2911 i have 4 EHWIC slot, i want to choose 3 EHWIC Interfaces to connect to PSTN Network ( 12 RJ11 jacks) and 1 EHWIC Interface to primary access ( 1 jack) . can you help me what's EHWIC interfaces i should choose?
