Prime Infrastructure 3.7 NCS reinstall
fiza258
Good afternoon, I would like to know how can I do reinstall NCS in prime infrastructure 3.7?, due to tests, We typed "application remove ncs" and therefore NCS was removed from the server, in this case there is an option to reinstall NCS again or is better reinstall the operating system
Jaime Valencia
You're posting in the UC/Collaboration area of CSC, might want to move your post to a relevant area for your question.
java
if this helps, please rate
balaji.bandi
If you like to install the application and like to test: below commands help you :
https://www.cisco.com/c/en/us/td/docs/wireless/ncs/1-0/command/reference/cli10/cli_app_a.html#wp2000299
My take is re-install and restoring from backup is a wise option.
BB
