Problem Configuring Incoming SIP calls CUCM7
nanosynth
After self teaching myself and help from others here, I have learned CME 4.1 & Unity Express, I bought a server and loaded CUCM7 and Unity on it. This is my first crack at Publisher, Subscriber and Unity. So far I have gotten two 7912 phones to call eachother and setup the voicmail on each. I have the server LAN'd to a 2621XM acting as an h323 gateway. I have two SIP numbers comming into it from the internet. I have successfully made calls from each extension out to the world. I can't call into the CUCM7, get fast busy. Just need to be pointed in the right direction and I will figure out the rest. My incoming dial peer, don't know if it's correct for CUCM7. Phones are SCCP.
dial-peer voice 1 voip
description To/From CUCM
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target ipv4:10.10.210.10  <--- IP of CUCM7
incoming called-number .%
dtmf-relay rtp-nte
no vad
Debug CCSIP Messages from 2621XM when call placed to CUCM7
INVITE sip:17275652954@10.10.210.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.210.1:5060;branch=z9hG4bKA32017
From: <sip:17272026330@216.115.69.144>;tag=439558-E40
To: <sip:17275652954@10.10.210.10>
Date: Fri, 23 Nov 2012 22:43:53 GMT
Call-ID: 1758E39F-34F611E2-8102E0F1-87FDF4FE@sip.flowroute.com:5060
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 390061477-888541666-2164121841-2281567486
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, R
CSeq: 101 INVITE
Timestamp: 1353710633
Contact: <sip:17272026330@10.10.210.1:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 94
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 278
v=0
o=CiscoSystemsSIP-GW-UserAgent 5826 170 IN IP4 10.10.210.1
s=SIP Call
c=IN IP4 10.10.210.1
t=0 0
m=audio 17608 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Nov 23 22:43:53.315: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Allow-Events: presence
Content-Length: 0
CSeq: 101 INVITE
Nov 23 22:43:53.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
Warning: 399 "Routing failed: ccbid=23 socket=10.10.210.1:5060"
Content-Length: 0
To: <sip:17275652954@10.10.210.10>;tag=941901863
CSeq: 101 INVITE
Of course I see the routing failed. What I don't understand is how to setup the phone in CUCM7 so that when it's called from the outside world, it recognizes the SIP message to ring it. In regular CME 4.1 my incoming dial peer setup was this, and it worked.
dial-peer voice 2 voip
redirect ip2ip
voice-class codec 1
voice-class sip localhost dns:sip.flowroute.com
voice-class sip dtmf-relay force rtp-nte
session target dns:sip.flowroute.com
dtmf-relay rtp-nte
no vad
I believe in CME4.1, how the phone knew to ring when called was this:
ephone-dn 1
number 17275652954 secondary 3001 no-reg both
How do I have to identify the 7912 phone in CUCM7 so it can respond to an incomming call, and do I need to modify my incoming dial peer?
Thank YOU!
3 Accepted Solutions
Can you send your full configuration..Send us a show run.
Also It looks like you have a h323 to sip setup
CUCM-------h323----->Gateway-------SIP------>ITSP
If this is correct then you need to make config changes...The dial-peer that sends call to your CUCM is dial-peer 1 and its configured to use SIP...Can you configure a second dial-peer as follows
destination-pattern 17275652954
no vad
dtmf-relay h245-alphanumeric
translation-profile incoming PSTN-IN
incoming called-number 17275652954
voice-class codec 1
no vad
dtmf-relay rtp-nte
dial-peer voice 3 voip
destination-pattern 3001
no vad
Now you will need to create a translation rule to change 17275652954 to 3001 (assuming 3001 is the internal extension in cucm)
voice translation-rule 1
rule 1 /^17275652954/ /3001/
voice translation-profile PSTN-IN
  translate called 1
So this is what this config does...
1. Incoming calls to Number 17275652954 is mapped to a sip leg/sip dial-peer
2. A translation prifle is applied to this leg and the called number is changed to 3001
3. The extension 3001 is then routed to cucm on a h323 leg
You also need to ensure that you have CUBE functionality enabled..because by default the gateway is not going to route incoming voip leg to outgoing voip leg...
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
will.alvord
Level 5
Level 5
It depends on how (or where) you want to handle the digit manipulation. You can do it on the gateway as described or on cucm. Just so you have both options -- under the 323 trunk incoming settings there's a digit length setting. Adjust or leave as is but then create a translation pattern with that length of your DID as the pattern with a mask of your extension.
There are multiple ways to skin the cat so to speak. It mostly comes down to where you're most comfortable - ios or cucm.
Sent from Cisco Technical Support Android App
Usually one way voice is a routing issue...But I had like us to do something first. Lets create a sip end to end connection.
So we will change your call flow to this:
CUCM--------sip-------->gateway--------sip-------->ITSP
To do this, you need to create a sip trunk to your gateway. You then do the ff:
1. You need to creata an inbound dial-peer for both cucm and sip provider to use sip as follows
incoming called number .
dtmf-relay rtp-nte
no vad
This dial-peer will be used to route calls from both sip provider and cucm (inbound to the gateway)
2. You then need to change the dial-peer that route calls to cucm from h323 to sip
dial-peer voice 4 voip
destination-pattern 1001
dtmf-relay rtp-nte
no vad
3. You need to enable sip to sip calls on the gateway
voice service voip
allow-connections sip to sip
Now do a test call..let me know what the result is
send debug ccsip messages
13 Replies 13
will.alvord
Level 5
Level 5
Way to go!  Great initiative.
Within cucm you'll need to add a connection to your gateway be it an h.323 gateway or sip trunk.  You could go with an mgcp gateway, but it looks like you're looking to learn gateway and cucm configs so you're left with the other 2.  Within either set of configs you'll see an inbound routing section.  Normally, you'd provision the lines of your phones in a partition.  Then you'd set the (h323 gateway or sip trunk) inbound css to a css containing that partition.
That should get you headed in the right direction.
will
I do have a connection to my gatway from CUCM and it is h323. I have outbound numbers mapped in that partition as well. Thats how I am able to dial out to the world on the two 7912 phones. I have only one CSS and one parititon in that CSS. Very basic. The phones are in that one partition in that one CSS. SInce my phones are in that partition with extension numbers 1001 and 1002, shouldn't an incoming dial peer in the 2621 written like this ring the one extension, or am I still missing something, like do I need to do incoming trranslations in the 2621XM to translate my incoming SIP number of 17275652954 to my extension number of 1001?
description To CUCM
voice-class codec 1
dtmf-relay rtp-nte
no vad
no vad
voice-class codec 1
no vad
dtmf-relay rtp-nte
no vad
  translate called 1
voice service voip
Thank you very much aokanlowon. The light came on when you said I had the setup of CUCM-->h323-->SIP-->ITSP and not the other way around. This is my config below, with the second two of your dial peers. The first dial peer listed messed up call procesing. Everything works now, but had a bug. When I called the CUCM from a landline, through my SIP provider to my CUCM, it rang the 7912 and when I answered the pots line kept ringing in my ear. I fixed that by enabling fast start incoming on the gateway CUCM page. Phones can call eachother now.
Still have two issues. When I use the landline to call into the CUCM 7912 phone, I cannot hear any speech on the landline phone when talking into the CUCM 7912 phone. If I speak into the landline phone, speech comes out of the 7912, so I have a one way audio issue here. No audio from CUCM to landline phone.
The DTMF tones do not pass to either phone. Of course I can't hear anything on the landline phone, so I don't know if the DTMF tones generated from the CUCM 7912 would make it though.
hostname CUCM_GATEWAY
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$uNta$f23yMXIpygHlTVta8z7Jz.
no aaa new-model
clock timezone EST -5
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp pool VOICE_20
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
   option 150 ip 10.10.210.10
no ip domain lookup
ip name-server 208.67.222.222
ip name-server 208.67.220.220
voice service voip
h323
sip
registrar server expires max 160 min 160
   localhost dns:sip.flowroute.com:5060
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
rule 1 /^9\(..........\)$/ /1\1/
voice translation-rule 2
rule 2 /^17275652954/ /1001/
translate called 2
voice translation-profile outgoing
translate called 1
archive
log config
hidekeys
interface FastEthernet0/0
description To CUCM
ip address 10.10.210.1 255.255.255.0
duplex auto
speed auto
ntp broadcast
h323-gateway voip interface
h323-gateway voip h323-id HVoiceGW1
h323-gateway voip bind srcaddr 10.10.210.1
interface Ethernet1/0
description Telnet Management
ip address 192.168.2.115 255.255.255.0
half-duplex
interface Ethernet1/1
description Ethernet To Internet Home Router
ip address 192.168.1.100 255.255.255.0
half-duplex
interface Ethernet1/2
description To Phones
ip address 192.168.20.1 255.255.255.0
half-duplex
interface Ethernet1/3
no ip address
shutdown
half-duplex
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 10.0.0.0 255.0.0.0 10.10.210.10
ip http server
no ip http secure-server
control-plane
description Outbound To Flowroute
translation-profile outgoing outgoing
destination-pattern 9..........
voice-class codec 1
session target ipv4:216.115.69.144
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
no vad
sip-ua
credentials username XXXX password XXXX realm sip.flowroute.com
authentication username XXXX password 7 XXXX
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:216.115.69.144 expires 60
connection-reuse
host-registrar
dtmf-relay rtp-nte
no vad
dtmf-relay rtp-nte
no vad
voice service voip
Ok, I completed what you asked. I am getting more proficient at this.. What we have now is the exact opposite of before. When I call the landline phone from the 7912, I get no voice on the landline phone but if I speak into it I can get voice on the 7912. I must confess the landline phone is a Brighthouse VIOP phone. Only one time out of like 10 test calls did it work voice both ways and DTMF both ways. It's not really that stable. Here is the ccsip's
SIP Call messages tracing is enabled
CUCM_GATEWAY#
Nov 24 19:32:06.351: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:17272026330@216.115.69.144:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK3181F08
To: <17272026330>
Date: Sat, 24 Nov 2012 19:32:06 GMT
Call-ID: 7716E3BC-35A411E2-83E6BCE8-24D7501A@sip.flowroute.com:5060
Min-SE: 1800
Cisco-Guid: 2151945376-3055554827-167780865-3232240652
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1353785526
Contact: <17275652954>
Expires: 180
Content-Length: 0
Nov 24 19:32:06.439: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <17272026330>
CSeq: 101 INVITE
Content-Length: 0
Nov 24 19:32:06.443: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
To: <17272026330>;tag=da160a8e0534d7b0db4afd8620a22cb7.639f
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.flowroute.com", nonce="ULEh4lCxILbi74Mhp2kX1LUm3Y3v/XPw", qop=
"auth"
Content-Length: 0
Nov 24 19:32:06.459: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:17272026330@216.115.69.144:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 24 19:32:06.463: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK31914DF
To: <17272026330>
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="86148921",realm="sip.flowroute.com",uri="sip:17272026330@216.1
15.69.144:5060",response="fc9b94fdefc76843bcd8b5e79c9e88bb",nonce="ULEh4lCxILbi74Mhp2kX1LUm3Y3v/XPw"
,cnonce="ABC8CB6C",qop="auth",algorithm=md5,nc=00000001
Content-Length: 0
Nov 24 19:32:06.939: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <17272026330>
CSeq: 102 INVITE
Content-Length: 0
Nov 24 19:32:09.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <17272026330>;tag=gK0b851454
CSeq: 102 INVITE
Record-Route: <216.115.69.133:5060>
Record-Route: <216.115.69.144:5060>
Contact: <>
Content-Length: 0
Nov 24 19:32:12.123: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixe
d
Contact: <>
Content-Length: 216
v=0
o=- 30309 24983 IN IP4 4.55.22.66
s=-
c=IN IP4 4.55.22.66
t=0 0
m=audio 26144 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=maxptime:20
Nov 24 19:32:12.211: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:+17272026330@4.55.22.99:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK31A20C9
Route: <216.115.69.144:5060>,<216.115.69.133:5060>
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 181
v=0
o=CiscoSystemsSIP-GW-UserAgent 6017 638 IN IP4 192.168.1.100
s=SIP Call
c=IN IP4 192.168.1.100
t=0 0
m=audio 16406 RTP/AVP 0
Nov 24 19:32:16.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:192.168.1.100:5060 SIP/2.0
Max-Forwards: 10
Record-Route: <216.115.69.144>
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK0631.be4607b649049cd3002df07ca6a8fcca.0
Via: SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:192.168.0.3:5060
Call-ID: 4861c687-acf89827-0fb2be3@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Nov 24 19:32:16.855: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK0631.be4607b649049cd3002df07ca6a8fcca.0,SIP/2.0/UDP 21
To: sip:192.168.0.3:5060;tag=1247080-227A
Date: Sat, 24 Nov 2012 19:32:16 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 OPTIONS
Supported: 100rel,resource-priority,replaces
Content-Length: 170
v=0
o=CiscoSystemsSIP-GW-UserAgent 4536 3362 IN IP4 192.168.1.100
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 15 3
Nov 24 19:32:17.091: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:+17272026330@4.55.22.99:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.100:5060;branch=z9hG4bK31B9E2
Max-Forwards: 70
Timestamp: 1353785537
CSeq: 103 BYE
Proxy-Authorization: Digest username="86148921",realm="sip.flowroute.com",uri="sip:+17272026330@4.55
.22.99:5060",response="9227cec4f478fe09c64d0f97292db6e5",nonce="ULEh4lCxILbi74Mhp2kX1LUm3Y3v/XPw",cn
once="DEBF9368",qop="auth",algorithm=md5,nc=00000002
Reason: Q.850;cause=16
Content-Length: 0
Nov 24 19:32:17.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
Before troublshooting further, do you want to try another phone?
Funny you should ask that. I tried my Metro PCS cellphone. When I call into the CUCM from the cell phone, the call is perfect and full DTMF both ways. When I call the cell phone from the CUCM, it rings, I answer it and then I get a fast busy on the CUCM 7912. Weird.. I wish I had a POTS line to start off with. I have to work tonight so I am going to research this for 12 hours at work.
Do a test call for the non working call..Please send the full debug ccsip messages. I need the debug to show the cucm side of the call please
Hi aokanlawon. Well, after woking 13 hours last ngiht in the NOC where I work at, I read ,researched, studied and created configs for my issues in 12.5 of those hours. What I came up with was a 100% SIP to SIP gateway configed in my 2621XM. The part I really had to learn was how to configure (correctly) the inbound and outbound SIP configs in the CUCM7. I got it all working rock solid. Calls in and out to both the Brighthouse VOIP phone and my Metro cell phone. No hangups, fast busys, one way audio...even the DTMF works both ways! I learned a lot from reading ccsip debugs too, probably cause you were asking form them all the time..haha..Well, thank you very much for all your help!
I must say what a great job you did! Well done! Thats the way to learn. You may want to shar your findings with others on the forum. Its the way we give back to this excellent forum, so that when others come across your thread, they can also benefit.
will.alvord
Level 5
Level 5
I hear what your saying. I learned right from IOS and I am halfway through CCNA class (Not CCNA Voice, hence my questions here) now, so I have a good IOS base, but I'm learning the CUCM GUI. It's got a lot to offer..
