Problem installing GB numbering plan
b.t
Trying to install and configure GB numbering plan.  I am using dp-ffr.3-1-14.GB.cop.sgn (I did just spot that 3-1-15 is now out, but it should not matter.  I have BE6K with CUCM 10.5.2.  I uploaded the installer fine onto both publisher and the one subscriber that we have OK.  I rebooted the cluster (pub then the sub), but when I go to add or modify a route pattern I only see NANP.  I double checked the installed upgrades as follows........
Publisher
admin:show version active
Active Master Version: 10.5.2.10000-5
Active Version Installed Software Options:
cm-locale-en_GB-10.5.2.2000-1.cop
cmterm-ata190.1-2-1-004.k3.cop
cm-locale-combined_network-10.5.2.2000-1.cop
ciscocm.platform-install-pwreset-v1.1.cop
Subscriber
After several (I don't know what else to do) reboots - still no joy.  Has anyone seen this?
Brian
Can you post a screen shot from call routing>dial plan installer..similar to the one below
Please rate all useful posts
Ayodeji Okanlawon
Have you installed the dial plan via cucm gui. You
 need to install it for you to use it.
Yes
Sigh
I was 100% sure that I had installed it here - but when I went to get the screen shot, I saw that version numbers were blank.........
Installed it - and it's fine now thanks.
