Problem Model IP Phone CP-7961 and CP-7941
marco.sirna
Hi All,
I need your help, we found that in the IP Phone Series CP-7961 and CP-7941 have problems to hook the handset and activate the speker. Is there a way to solve it?
Appearance Your remarks.
Thank you.
Greetings,
Marco.
5 Replies 5
testeven
Hi Marco,
What type of problem do you have? This might be a hardware issue, does this happen with more than 2 phones? If you think this is a hardware problem you might need to open a TAC case for an RMA.
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
Hi Tere,
if it is outside maintenance of Cisco? A colleague of mine opened in IP phone looks like it defective the contact is not There Any Way of fix this and it lasts for a while?
Thanks for your interest.
Greetings,
Marco.
Rob Huffman
Hi Marco,
I just wanted to add a note to the good info from Tere (+5 "T").
This is a very common problem that has plagued these models of IP phones for years. Here is a an old thread with some more recent comments that discuss the repair/replacement of many of the "hookswitch" parts that cause these issues;
https://supportforums.cisco.com/discussion/10857716/7961-onoff-hook-issue
The parts are available for a fairly reasonable cost @ many suppliers. Here's one example that I found with a quick Google search;
http://www.buytelephoneparts.com/cisco/
If you search YouTube you will even find some step-by-step videos.
Cheers!
Rob
Hi Rob,
Thank you very much for your interest.
Marco S.
More over, there are so many eBay based resellers selling 7900s that, it may in fact be easier and cheaper to replace the phones than the individual switch.
