Problem on QSIG link between 2811 and Alcatel 4400
malosse
Hello
I've problem with QSIG link.
Architecture:
I've 2811 connected to OMNI PCX 4400 Alcatel with QSIG link.
On the OMNI PCX, i've, MOH device when i call specific number.
Problem:
When i call the "specific number" from my Ip phone connected on my LAN behind the router 2811, the call are OK. I listen the MOH and after short time, the called agent hang off is phone => OK!
When i call the same specific number from outside, the caller doesn't listen MOH. However, the called agent is ringged and can hang on the call ...
Changed done without effect:
- We have also changed the identity of the caller from translation pattern ...
- We have change Plan:ISDN, Type:National to unknown, unknown ...
Does anyone can help me ?
15 Replies 15
paolo bevilacqua
As I understand that, you should have two ISDN links, one qsig to the omni, one to pstn. Please send output of "debug isdn q931" for both the successful call from the IP phone, and the "no moh" call from outside.
Hello
I've on T2(E1) on 2811 to the OMNI, and 1 T2 (E1) to the PSTN.
In fact, i've 2 router connected together via LAN network.
Trace with problem:
*Jun 5 17:32:32.955: ISDN Se0/1/0:15 Q931: RX <- NOTIFY pd = 8 callref = 0x8003
Notification Ind i = 0xF9
*Jun 5 17:32:33.191: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x8003
Facility i = 0x91AA068001008201008B0100A11602022EEC06042B0C090C300A0A0101820080000A0101
*Jun 5 17:32:33.199: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x8003
Facility i = 0x91AA068001008201008B0100A11C02022EE106042B0C090180104A5556454E54494E204D6968696D616E
*Jun 5 17:32:35.407: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x8003
Facility i = 0x91AA068001008201008B0100A12F02022EEB06042B0C090B3023A0098004363738390A010040049532018180104A5556454E54494E204D6968696D616E
Notification Ind i = 0xFA
*Jun 5 17:32:45.903: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0004
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Calling Party Number i = 0x2181, '414402'
Called Party Number i = 0x80, '7794'
Plan:Unknown, Type:Unknown
*Jun 5 17:32:45.935: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8004
Channel ID i = 0xA1839E
Preferred, Channel 30
*Jun 5 17:32:45.939: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8004
Progress Ind i = 0x8088 - In-band info or appropriate now available
Locking Shift to Codeset 5
Codeset 5 IE 0x32 i = 0x81
*Jun 5 17:32:45.999: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x8004
*Jun 5 17:32:55.707: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0005
Sending Complete
The trace you sent is incomplete, it misses "connect" from PBX.
Anyway the problem be due to the router not enabling the audio path between alerting/progress and connect.
Please see:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml#vpcutthru
in short, what may be needed is:
voice rtp send-recv
hope this helps, please rate post if it does!
Hello
Sorry, for the missing trace ... ;-)
When we place from the inside LAN (from Cisco IP phone connectd on the LAN behind the 2811), the MOH sent by the OMNI work well ...
This the trace of the call:
*Jun 5 17:31:25.815: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0002
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Facility i = 0x91AA06800100820100A11602010106042B0C0900800B434F554C4F4E2052656E65
Calling Party Number i = 0x0081, '4402'
*Jun 5 17:31:25.859: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8002
Channel ID i = 0xA1839F
Preferred, Channel 31
*Jun 5 17:31:25.863: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8002
*Jun 5 17:31:25.899: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x8002
*Jun 5 17:31:37.907: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = 0x8002
Facility i = 0x91AA068001008201008B0100A11202022EE106042B0C09018006434349565238
*Jun 5 17:31:37.935: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8002
Facility i = 0x91AA068001008201008B0100A11202022EE206042B0C09028006434349565238
Progress Ind i = 0x8082 - Destination address is non-ISDN
*Jun 5 17:31:37.943: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0002
*Jun 5 17:31:40.103: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0002
Cause i = 0x8090 - Normal call clearing
*Jun 5 17:31:40.135: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8002
Cause i = 0x809080 - Normal call clearing
*Jun 5 17:31:40.155: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0002
*Jun 5 17:32:11.919: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0003
Sending Complete
However, when the call came from outside the network, but routed by CCM, the MOH sent by OMNI doesn't work well ...
We listen only the ring back tone sent by OMNI ...
Many thanks for your help :-D
I think, the router on which you took the trace ("OMNI router"), is behaving correctly, we know that because OMNI is sending alerting and progress, the voice path should have been established, according to the document I've linked before.
But, we cannot be sure that the CCM and other router ("PSTN router") are doing the same, in fact if you hear ringback and not moh, this means the ringback is originated by the router and not the OMNI.
Now, to complete the investigation, how the "PSTN router" is connected to CCM, H.323 or MGCP? Can you configure "PSTN router" to send the call from outside directly to "OMNI router" without going through CCM ?
Hello
To solve the problem (... temporarily ...) it's what we done!
When call came to the 1st router, we add policy to resend the call oustside the router to the OMNI via PSTN ... and it works ...
We don't arrive to decode the facility sent on QSIG link.
The MT.EXE tool doesn't arrive to do this ...
We don't know if the problem is on this sequence ... but, if you can to decode this frame, we would be happy :-D
I tried to represent the problem
Architecture
[PSTN Cloud ]---T2---[2811 RTR]----LAN----[2811 RTR]---QSIG Link---[OMNI PCX]
1st | 2nd
IP Phone
Call from LAN IP-Phone -> MOH on Omni Ok !
From ===============================> OK!
1st | 2nd
IP Phone
Call from outside to Omni -> Not well (no MOH!)
From ==============================================================> Nok !
1st | 2nd
IP Phone
Bypass ok
From ==============|
[PSTN Cloud ]---T2---[2811 RTR]----LAN----[2811 RTR]---QSIG Link---[OMNI PCX]--[PSTN Cloud ]
IP Phone
I hope this graphic can help you to understand my problem
Many thanks for your time spend to this problem
Manu ;-)
not much time spent, I've seen worst.
I think the problem has nothing to do with the qsig facility, and happens because with the two routers, there is no voice cut-trough to allow the moh to pass before connect.
There are debugs commands to check this, if you want to.
But before you do debugs, you have mentioned there is a CCM, but to router the call from "PSTN router" to "OMNI router", you've used a dial-peer pointing directly, correct? Are you using SIP or H.323 for this ?
Have you tried the "rtp send-recv" command I've indicated before ?
hello
Well
We have tried your command, but no success :-(
All gateway use H323.
The thing which we do not explain is: when call is place from LAN, all is OK, but when call arrive from PSTN, the OMNI PCX 4400 ALCATEL doesb't want to play the MOH.
I don't remember if i explain this, but, the MOH is on the ALCATEL PBX (connected via QSIG to our 2811 router)
Best regards
Manu
Hi Manu,
Have you tried the command on both routers ?
The thing is that when you call from an IP phone, you go through one router, but when you call from PSTN, you go through two.
In the second case, the backward voice path is not completed before "connect". And the ringback you hear is generated by "pstn router".
Please go over the document in linked in first place to understand what I'm talking about.
Then I can think some debug to prove my hypothesis.
Hello
Well ...
I'm trying this in next nights (because incoming call can arrived from many GW (2811) and when i typed your command all call are stopped ...)
I think we can speak about this in few days
Many thanks paolo for your precious help ;-)
Manu
Dear Paolo
We have done your proposition in all routers ... but without success ...
Now, we think, the problem is located on the Alcatel PBX ... around the codec negotiation between Alcatel and Cisco router.
However, did you how can we decode the QSIG facility ?
Many thanks
Manu
Hi Manu,
In the "PSTN router", do you have "codec g711" on DP voip that points to "QSIG router" ?
I don't think it;s a problem of codec, because the call works, is just that you don't have backward voice cut-trought before operator answer.
Anyway,if you configure:
voice service voip
qsig decode
The router will decode the qsig message.
Good luck!
Also, if you want to compare your installation with the recommendations by cisco, look at this interesting document, if you haven't already.
http://www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/cme40/pbxint/588366nt.pdf
dear Paolo
Many thanks for this documentation ...
I haven't it
I'll read it and in hope found solution of my problem ;-)
Many thanks for this :-D
Manu
