05-11-2013 07:50 PM - edited 03-16-2019 05:16 PM
Having trouble getting a 2621xm to register with Flowroute SIP provider.
show sip-ua register status comes up with nothing:
R2#sh sip-ua register status
Line peer expires(sec) registered
R2#
I'm trying to integrate the 2621xm into my existing home network to setup a voip test lab. The network layout is like so:
ISP -> Cable modem -> Linksys E4200 w/DD-WRT -> 2621xm
I'm able to connect to flowroute and make calls using the X-Lite softphone on a PC connected to the Linksys.
Could the 2621 be having trouble with the NAT running on the linksys? I've tried forwarding ports 5060 and 10000-20000 in the linksys to the 2621's internal IP (192.168.2.9) and I also tried putting the 2621 in the linksys DMZ, but still no luck with the sip registration.
2621xm config is attached. Please help me troubleshoot, I'm a voip newbie.
Thank you!
Solved! Go to Solution.
05-14-2013 09:49 PM
I am no CUBE expert, but can you try the following:
> Lets try and decrease the timer value :
sip-ua
registrar dns:sip.flowroute.com expires 60
retry register 10
> Also from the config which you posted, if 12345 is the username which the ITSP provided, then try the following:
telephony-service
max-dn 1
ip source-address 192.168.2.9 port 2000
ephone-dn 1
number 12345
Let me know if that helps, if it does not please collect the debugs with the config in place and update.
Jagpreet
05-13-2013 03:53 PM
Ok, I've bypassed the linksys and connected the 2621 directly to my cable modem. I can ping out to sip.flowroute.com and there are no inbound access rules.
But the router is still not sending sip packets to flowroute. I engaged flowroute support and they confirmed they are not seeing sip packets on their end. What can I try to fix this?
Thank you.
05-13-2013 07:15 PM
Can you run debug ccsip to see what is going on, I would be particularly interested to see if your 2621 is actually trying to register with flowroute. (attach output)
also, is your 8.8.8.8 name server correct?
can you resolve sip.flowroute.com from the router?
Please remember to rate useful posts, by clicking on the stars below.
05-13-2013 07:26 PM
debug ccsip all shows nothing. It's like the router isn't even trying to reach out to sip.flowroute.com.
I waited a few minutes, but no messages in the terminal:
Router#debug ccsip all
This may severely impact system performance. Continue? [confirm]
All SIP Call tracing is enabled
Router#
Router#
Router#
Router#
8.8.8.8 is the dns server I'm using for testing. No problems with name resolution:
Router#ping sip.flowroute.com
Sending 5, 100-byte ICMP Echos to 216.115.69.144, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 88/88/92 ms
Router#
Thank you.
05-14-2013 08:37 PM
I'm seeing these messages in the debug:
Router(config)#
*Mar 2 03:43:42.301: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_configured_dest_patterns: No destination patterns to Register
*Mar 2 03:43:42.301: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: Primary registrar DNS resolved addr reset
Router(config)#
Any ideas? Thanks.
05-14-2013 09:49 PM
sip-ua
retry register 10
telephony-service
max-dn 1
ephone-dn 1
number 12345
Jagpreet
05-15-2013 05:46 AM
Jagpreet, thank you very much! This command got it working:
ephone-dn1
number 12345
As soon as I entered that, the debug messages started flowing and the router sucessfully registered with Flowroute:
Router#sh sip-ua register status
12345 20001 2062 yes
Router#
Thanks for the help!
