Problem to access by Browser in Cisco IP Phone 7940
javierhugo22
I don't why I can't access by browser to my cisco IP phone 7940, I can ping phone's IP address but don't access by browser. The firmware version Information is:
Application Load ID:     P0S3-08-2-00
Boot Load ID:              PC030301
DSP Load ID:              PS03AT47
I also want to install and XML application but I don't know how to make my phone to read the XML applicacion. I hope someone can help me.
Jaime Valencia
Is web access enabled on the phone???
As for apps I'd start here:
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
and where is the web access option? cause in network configuration I can't find that option.
About the application I already have some application what I need is my cisco IP phone 7940 call the XML applications, I don't know how to do this
PD: I'm not using CM
i have same problem in CISCO IP Phone 7940 can't access from Web browser ip configuration is done and phone is normal can call and Receive the call
@esmatullahattayee I encourage you to open a new discussion rather than commenting on a 13-year-old post. You'll get more help that way.
When you post, please include whether you are using CUCM and what version, or if you are using CUCM Express.
Maren
