08-19-2010 12:32 PM - edited 03-16-2019 12:21 AM
Hi Guys,
I had configured the CallManager 6.0 and it was working normally. When I changed the IP of CallManager and tried to access the administration page, the CallManager didn´t accept the username and password and no error message was shown, it just asks the username and password again. When I return to the previous IP the CallManager worked again. I Collected the message bellow:
%CCM_TOMCAT_APPS-JAVAAPPLICATIONS-0-EMAppNotStarted:EM Application not started Servlet Name: Cisco Extension Mobility Application App ID:Cisco Tomcat Cluster ID:Laboratorio
I Tried to change the password, but, I get the following message error:
failed to get connection.connector(not connected:driver=com.informix.jdbc.ifxDriver
code = 1 authorization failure
Any idea?
Wilson
Solved! Go to Solution.
08-19-2010 12:58 PM
Oh your welcome!!
08-19-2010 12:45 PM
Take a look at the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/ipchange/ipchg611.html
Hope this helps.
Justin
08-19-2010 12:57 PM
Hi Justin,
Tomorrow I will do the tests and answer for you about the results.
Thank You,
Wilson
08-19-2010 12:58 PM
Oh your welcome!!
08-23-2010 10:20 AM
Hi Justin,
In last friday I did the test and worked. Thanks a lot for you help.
Wilson
