problem to receive fax with onramp application
gevangelista
       Good morning I'm triyng to confiure the t37 fax to mail using onramp application.
When I'send a fax from external site to  cisco voice-gw running onramp application, with the "debug mta send all"
I receive  the following error message:
%LAPP_ON_MSGS-6-LAPP_ON_CAUSE_NO_ESMTP_CONNECT: ESMTP client did not connect or lost connection to remote server.
Can you help me to solve this problem:
Thanks in advance
giancarlo
Did you reload your router after adding the 'fax interface-type fax-mail' statement?  Is your mail server reachable by the router?
9 Replies 9
will.alvord
Level 5
Level 5
Just shooting from the hip here, but check the 'mta send mail-from' or 'mta send postmaster' statements.  If that doesn't work, please post your configs.
Hi Will   at following the actual configuration
ip domain name qualisystem.ch
ip name-server 172.16.41.12
ip name-server 192.168.10.1
ip inspect WAAS flush-timeout 10
isdn switch-type basic-net3
isdn tei-negotiation first-call
trunk group ALL_BRI
hunt-scheme longest-idle
fax send max-speed 9600
fax send left-header $a$
fax send center-header GFL $a$
fax send right-header $p$
fax send coverpage enable
mta send server 194.209.125.46 port 25
mta send subject Nuovo FAX in Arrivo
mta send mail-from hostname Voice-GW-GFL-Lugano.qualisystem.ch
mta send mail-from username $s$
mta receive aliases qualisystem.ch
mta receive maximum-recipients 10
mta receive generate permanent-error
application
service onramp flash:app_faxmail_onramp.2.0.1.3.tcl
service offramp flash:app_faxmail_offramp.2.0.1.1.tcl
d
tftp-server flash:app_faxmail_onramp.2.0.1.3.tcl
tftp-server flash:app_faxmail_offramp.2.0.1.1.tcl
control-plane
voice-port 0/0/0
translation-profile incoming ENTRANTI
compand-type a-law
cptone CH
bearer-cap Speech
voice-port 0/0/1
compand-type a-law
cptone CH
bearer-cap Speech
mgcp profile default
dial-peer voice 50 pots
tone ringback alert-no-PI
description DIAL-PEER PER CHIAMATE USCENTI VERSO LA PSTN
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
port 0/0/0
no sip-register
dial-peer voice 51 pots
direct-inward-dial
port 0/0/1
no sip-register
dial-peer voice 1 voip
description chiamata in ingresso su GFLUCM1
destination-pattern 5..
session target ipv4:172.16.41.240
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 1581 mmoip
description ** Gestione Fax-to-Mail Federica Tronti**
service fax_on_vfc_onramp_app out-bound
destination-pattern 581
information-type fax
session target mailto:giancarlo.evangelista@qualisystem.ch
dial-peer voice 581 pots
description **Chiamata per fax in ingresso Federica Tronti**
service onramp
service onramp out-bound
incoming called-number 581
direct-inward-dial
port 0/0/1
Hi Will. rhe router was been reloaded more times.
The mail server is reachable: if I  send a telnet of mail server Ip address on port 25 (smtp) the server answer me.
The server it's not reachable by ping, but I' think that can be a normal statement.
There are a couple of statements I have in my test gateway which you're missing.  Although they don't appear to be the problem, it's worth a shot to add them.
fax receive called-subscriber $d$
mta send with-subject both
mta send postmaster whatever@qualisystem.ch
mta send return-receipt-to hostname qualisystem.ch
mta send return-receipt-to username whatever
Hi Will, I've added the suggested  items, but the situation it's the same.
Grasping at straws, but is 194.209.125.46 the correct address of your mail server?
yes the mail server ip address it's correct.
Well the error points to an incorrect/missing SMTP server config.
Here is a link with some additional debugs and a step by step troubleshooting guide:
https://supportforums.cisco.com/docs/DOC-25638
