01-04-2013 06:07 AM - edited 03-16-2019 02:59 PM
I've the problem in object.
I' ve connected the phone to th switch poe.
The phone get an ip address from dhcp server but the display remain blank and the phone is not registering on the cucm.I think coulde be a firmware uograde probleem.
Can you help me?
Thanks in advance
Giancarlo
Solved! Go to Solution.
01-04-2013 12:07 PM
SIP or SCCP? do you have a DN already assigned to the phone?
Output of the status messages from the phone would be helpful.
01-07-2013 02:24 AM
Hi Giancarlo,
We have the same issue on with this version of callmanager, when we configured a 6945 phone on sip it registered with no problems. all other types of phones we had dit register correctly with sccp.
maybe this is the solution for you problem.
I hope cisco will come soon with a solutions because the sip protocol is no option for us.(firewall)
did you also try to install the following cop file on the Callmanager TFTP servers:
cmterm-6945-qed.9-1-1-0.cop.sgn
HTH,
Edwin
01-04-2013 07:10 AM
Do you have other models working? At the same location and on the same network segment?
Is the phone getting TFTP address? Is it configured in CUCM or are you using auto registration? What are you seeing on status messages on the phone?
HTH,
Chris
01-04-2013 07:57 AM
Hi Chris.
I've 150 iphone working on this cucm, but it's the first 6945 instalall are ok (tftp, auto registration and so on) but on the phone display doesn't appears nothing!!!!!!!
01-04-2013 12:07 PM
01-07-2013 02:24 AM
Hi Giancarlo,
HTH,
Edwin
01-07-2013 03:13 AM
Hi Edwin,
I've solved the problem in the following mode:
I've downloaded the cmterm-6945-qed.9-1-1-0.cop.sgn and after the firmware file.
I've configured the cucm with this firmware and a this poitn the phone has been registered.
Thanks for your help
Giancarlo
06-23-2022 06:37 AM
Can you send me this version, and example SEP......xml
cmterm-6945-sip.9-1-1-0.cop.sgn
