04-01-2013 06:08 AM - edited 03-16-2019 04:32 PM
Good day
Today, I've bought L-CM-DL-10= for CUCM 9.1, but when i tried to activate this license through ELM and have entered a correct PAL, i've received an error
An error occurred while attempting to process the request. If the problem persists, open a Service Request using the
or contact the Cisco Technical Assistance Center (TAC) at 888-553-2447.
Then, i've generated a license through Product License Registration, downloaded .lic file and tried to upload it to ELM, but agate i've receid error
Mac address, which i entered, while generating .lic file in other try is correct
What is a mistake?
Thanks;)
Solved! Go to Solution.
04-01-2013 06:25 AM
These are DLU licenses which are not applicable to CUCM 9.1, you need to purchase either CUWL or UCL type licenses. Whoever you purchased it from should know better what to sell for your version, DLUs have been discontinued from quite some time.
Also read about ELM as MAC address is no longer applicable as well.
HTH,
Chris
04-01-2013 06:25 AM
HTH,
Chris
04-01-2013 06:53 AM
And how i can buy such license, i've "generated license request" and what are the next steps to buy a license ?
04-01-2013 07:05 AM
No, you need to order the licenses from Cisco reseller after which time you will receive a PAK number that you register against the ELM instance.
Chris
