Problem with MGCP gateway
kuliyevnatik
I am having an issue with an MCGP gateway and CUCM 8. The MGCP gateway status is shown as unregistered in CCM. Below is the config of the MGCP gateway and here as you can see it.
Voice>en
Voice#sh run
Building configuration...
Current configuration : 2858 bytes
! Last configuration change at 19:00:54 UTC Mon Oct 15 2012
! NVRAM config last updated at 18:33:33 UTC Mon Oct 15 2012
version 15.1
hostname Voice
boot-start-marker
boot-end-marker
card type e1 0 0
! card type command needed for slot/vwic-slot 0/1
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip domain name baltika.local
isdn switch-type primary-net5
voice-card 0
license udi pid CISCO2911/K9 sn FCZ163120XY
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 5
ip address 10.80.2.2 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.80.2.1
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
voice-port 0/0/1:15
ccm-manager redundant-host 10.80.2.11
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.80.2.10 10.80.2.11
ccm-manager config
mgcp
mgcp call-agent 10.80.2.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/0.1
mgcp bind media source-interface GigabitEthernet0/0.1
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Voice#
Voice#
Voice#sh ccm
MGCP Domain Name: Voice.baltika.local
Priority        Status                   Host
Primary         Registered               10.80.2.10
First Backup    Backup Ready             10.80.2.11
Second Backup   None
Current active Call Manager:    10.80.2.10
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            20:10:24 UTC Oct 15 2012 (elapsed time: 00:00:02)
Last MGCP traffic time:         20:10:24 UTC Oct 15 2012 (elapsed time: 00:00:02)
Last failover time:             18:58:39 UTC Oct 15 2012 from (10.80.2.10)
Last switchback time:           18:59:24 UTC Oct 15 2012 from (10.80.2.11)
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  10.80.2.10
    Current Link State: OPEN
    Statistics:
        Packets recvd:   2
        Recv failures:   0
        Packets xmitted: 2
        Xmit failures:   0
    PRI Ports being backhauled:
        Slot 0, VIC 0, port 1
        Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1350325725-ad4502fa-0427-473b-9107-b4fc0fbac1ba
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 16
          Download Successful          : 16
          Download Failed              : 0
          TFTP Download Failed         : 0
        Configuration Attempted        : 1
          Configuration Successful     : 1
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
no network-clock-participate wic 0
end
end
Voice#
Hardware vwic slot and port is right with gateway mgcp config, but status is unregistered again
18 Replies 18
That's correct' it will not register unless physically connect to your carriers equipment.
Allan
Allan,
your approach to the diagnosis of the problem was very helpful, thank you
Problem solved, many thanks
No problem, thank you for the rating.
Allan
