Hi,Is there a way to route calls on CCME based on the calling number?The problem is like this:I have a couple of phones that i always want to go out on a sip trunk.The rest of the phones should use the analog lines.Thank you,laszlo
Hi, guys.Is it possible to configure a secondary number (to use DID [Direct Inward Dialing]) on an IP Phone 9971 using SIP on my network?For example, my extension number (Internally) is 11.I want to set a number so that anyone ( Out of my office) can...
HiGuys,Im facing an issue...I've configured correctly, but cant configure an external (secondary) number for 9971.Any help?-- Regards Edson Vuma
Greetings.I have a point - to - multi point MPLS network that is using VRF groups with MPLS/EIGRP/BGB (I am not verify familiar with routing protocols). When a phone goes into srst mode, they do not register with the local gateway. I am able to rep...
We have some Cisco switches - WS-C2960S-48LPS-LWe got these specifically for when we upgrade our phone system to Voip.Now I've had some potential supplier in today re. Voip and they have told us that these switches are no good re. QoS and we need to ...
Hi Friends , i have installed SIP trunk & incoming and outgoing calls are working fine but i am facing the issue on incoming fax call.let says Service provider------SIP Trunk----------CISC...
Guys,Is there any way to get a text based CLI For external numbers, like the alerting name function for IP phone to IP phone?So for example could I do something so that If I call into an IP Phone from my mobile/cellphone, it will come up with my name...
Hi everybody.IP phone refers to cisco ip phone in following discussion.ipphone----f0/2---SW--f0/1---trunk-----CME (router) | | f0/3 ...
Dear AllI have two CUCM (publisher , Subscriber ) version 7.1.5 MCS server , my Questions are following as below : 1) if i want to upgrade to 8.0 , it will be directly from install/upgarde software then put CD/DVD version 8 then upgarde ????? or i h...
I am trying to get CUCM 8.6(2a)SU2 on a brand new MCS7835-I3-K9-CMD2 server and am running into an odd issue. I've verified (and TAC has confirmed) that all versions of 8.6 are supported by my server (with no hardware upgrades required). Here is a d...
Hi everybodyI am just starting my telephony lab. I got few questions.1)We have a CME router, which command can we use to find cme version?2) How can we find supported cisco ip phone for a particular cme version?thanks and have a great a day
I'm looking at a client UC setup at the moment, and the NTP reference for CUCM and CUC is a lab one that is now inaccessible. I don't want to remove and change this because I'll have to go through the licencing again.My question is - can I add a sec...
Hi NetProI have a CUCM 8.5 and I created the bat file for bulk insert phones specific details, create the template and upload the file, the result for the validation it's OK. but when i try to insert the phones i have this error.Insert Phones - Speci...
Hi all,I have an issue where after a CUCM upgrade (and associated firmware upgrade) the 7942 phones are not displaying missed/received calls. I've discovered that a manual factory reset fixes the issue.My question is - can I factory reset and force ...
Hi I would like to know if there any USB speakerphones that integrate with CIPC V7? I have recently purchased a Polycom CX100 , but it appears that the On-hook, Off hook and mute controls on that speakerphone do not work with CIPC. The volum...
Subject | Author | Posted |
07-23-2025 12:10 PM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
11 | |
2 | |
2 | |
1 | |
1 |
