Problem with MGCP gateway
kuliyevnatik
I am having an issue with an MCGP gateway and CUCM 8. The MGCP gateway status is shown as unregistered in CCM. Below is the config of the MGCP gateway and here as you can see it.
Voice>en
Voice#sh run
Building configuration...
Current configuration : 2858 bytes
! Last configuration change at 19:00:54 UTC Mon Oct 15 2012
! NVRAM config last updated at 18:33:33 UTC Mon Oct 15 2012
version 15.1
hostname Voice
boot-start-marker
boot-end-marker
card type e1 0 0
! card type command needed for slot/vwic-slot 0/1
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip domain name baltika.local
isdn switch-type primary-net5
voice-card 0
license udi pid CISCO2911/K9 sn FCZ163120XY
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 5
ip address 10.80.2.2 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.80.2.1
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
voice-port 0/0/1:15
ccm-manager redundant-host 10.80.2.11
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.80.2.10 10.80.2.11
ccm-manager config
mgcp
mgcp call-agent 10.80.2.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/0.1
mgcp bind media source-interface GigabitEthernet0/0.1
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Voice#
Voice#
Voice#sh ccm
MGCP Domain Name: Voice.baltika.local
Priority        Status                   Host
Primary         Registered               10.80.2.10
First Backup    Backup Ready             10.80.2.11
Second Backup   None
Current active Call Manager:    10.80.2.10
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            20:10:24 UTC Oct 15 2012 (elapsed time: 00:00:02)
Last MGCP traffic time:         20:10:24 UTC Oct 15 2012 (elapsed time: 00:00:02)
Last failover time:             18:58:39 UTC Oct 15 2012 from (10.80.2.10)
Last switchback time:           18:59:24 UTC Oct 15 2012 from (10.80.2.11)
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  10.80.2.10
    Current Link State: OPEN
    Statistics:
        Packets recvd:   2
        Recv failures:   0
        Packets xmitted: 2
        Xmit failures:   0
    PRI Ports being backhauled:
        Slot 0, VIC 0, port 1
        Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1350325725-ad4502fa-0427-473b-9107-b4fc0fbac1ba
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 16
          Download Successful          : 16
          Download Failed              : 0
          TFTP Download Failed         : 0
        Configuration Attempted        : 1
          Configuration Successful     : 1
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
no network-clock-participate wic 0
end
end
Voice#
Hardware vwic slot and port is right with gateway mgcp config, but status is unregistered again
2 Accepted Solutions
Hi All,
I agree with Allan, AIS means problem on the far end:
http://www.cisco.com/en/US/customer/tech/tk713/tk628/technologies_tech_note09186a00801069ff.shtml
Receive Alarm Indication Signal (Blue)
A receive (Rx) alarm indication signal (AIS) means there is an alarm  occurring on the line upstream from the equipment that is connected to  the port. The AIS failure is declared when an AIS defect is detected at  the input and still exists after the Loss Of Frame failure is declared  (caused by the unframed nature of the "all-ones" signal). The AIS  failure is cleared when the Loss Of Frame failure is cleared.
You need to get in contact with your Telco.
To further test your E1, you can make a loopback test:
controller e1 0/0/0
loopback diag
Then you can issue "show controller e1 0/0/0"; interface showuld go UP.
The MGCP E1 will not register until the interface is UP.
Jorge Armijo
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
That's correct' it will not register unless physically connect to your carriers equipment.
Allan
18 Replies 18
Leonardo Santana
In cucm did you config the same domain for MGCP?
try this on the GW no mgcp / mgcp
try deleting and adding again the GW at CUCM
Leonardo Santana
*** Rate All Helpful Responses***
Jorge Armijo
Level 4
Level 4
Please make sure that the MGCP Domain name in CUCM is "Voice.baltika.local", this is the result from show ccm-manager.
Jorge Armijo
Thnaks for replay but name is right
Can you post your CUCM config?
Leonardo Santana
allan.thomas
Level 8
Level 8
It appears that you have two E1 wics, one of which you have specified to the correct card type. Typically the interface fails to register due the protocol layer being down with the SP. can you confirm the "show isdn status", do you have multiple frame established?
Yes, i have 2 E1 card and no body not connected to SP
here
Voice>en
Voice#sh isdn status
Global ISDN Switchtype = primary-4ess
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 1
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN Serial0/0/1:15 interface
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
Voice#
Looks like you have no layer 1 status with your carrier. Can you post a " show controller e1", this will give us an idea why the interface is not connected.
Voice#sh controller e1
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver is getting AIS.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (200 seconds elapsed):
     1638200 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 200 Fr Loss Secs, 200 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 200 Unavail Secs
  Total Data (last 1 15 minute intervals):
     7289507 Line Code Violations, 25 Path Code Violations,
     0 Slip Secs, 871 Fr Loss Secs, 894 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
E1 0/0/1 is administratively down.
The receive ais indicates that you have an issue with the upstream equipment, there are error frames and violations. Have you raised this with your carrier?
Allan
that is, do you mean for that would changed the status changes to "register" to raise the full link? that is to be set up and plugged the cable from above standing equipment?
Hi All,
controller e1 0/0/0
loopback diag
Jorge Armijo
Yes !
loopback diag -- solv my problem
Thanks a lot
Incidentally, has your carrier advised on the framing and line coding they are using? The alarms and errors could be as a result of incorrect settings. Are they using non-crc framing?
Allan
Thanks`s Allan for your help
But i want to say you that now i don`t have a link from my SP or anyhere.
that is, until I plug the working link to the E1 port status will not change?
