procedure to download BAT.xlt file in CUCM 6.1.3
sementellic
Can someone please send me the link or the procedure on how to download the BAT.xlt template for CUCM 6.1.3?
Thank you.
Carla
Jaime Valencia
Just go to the upload/download option from BAT menu, find the xlt. select it and click on download selected.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Rob Huffman
Hi Carla,
Creating a CSV File by Using BAT.xlt
Procedure
Step 1 The BAT.xlt file exists on Cisco Unified Communications Manager server; however, you normally do not have Microsoft Excel installed on the Cisco Unified Communications Manager server. In that case, you must copy the file from the Cisco Unified Communications Manager server and move it to the local machine, which must have Microsoft Excel installed.
Step 2 Choose Bulk Administration > Upload/Download Files. The Find and List Files window opens.
Step 3 Click Find and download the BAT.xlt file. For more details on uploading or downloading files, see Chapter 2, "Uploading and Downloading Files."
Step 4 Copy BAT.xlt to a local machine where Microsoft Excel is installed.
Step 5 In Microsoft Excel, open BAT.xlt.
http://www.cisco.com.az/en/US/docs/voice_ip_comm/cucm/bat/6_1_1/t10cpgin.html
http://www.cisco.com.az/en/US/docs/voice_ip_comm/cucm/bat/6_1_1/t02updn.html#wpxref46315
Cheers!
Rob
