07-12-2010 01:07 AM - edited 03-15-2019 11:39 PM
Hello All,
I would like to know if it is possible to forward a call on an IOS gateway that has come from PSTN back to PSTN without using the CCM.
Thanks for any advice.
Fraser
Solved! Go to Solution.
07-12-2010 02:30 AM
Translate called number with a profile. Apply it on the voice port, incoming.
07-12-2010 01:08 AM
Yes, you can configure a translation profile and rule to do that.
Or a minimal CME config.
07-12-2010 01:16 AM
can you help me out here by showing me a link to the correct PDF or giving the config to divert say
0401167422155
into
051167422157
I have a C-2950 with 15 IOS
Thanks for the FAST reply
07-12-2010 01:58 AM
Do you have ISDN ? Or just FXO ?
07-12-2010 02:19 AM
A PRI PSTN connection (30 channel)
07-12-2010 02:30 AM
07-12-2010 03:40 AM
so....something like
voice translation-rule 500
rule 1 /532011980/ /1167422159/
rule 2 /532011980/ /1167422159/
then on port
voice-port 0/0/0:15 ?
