Publisher request Recovery
hjacquemin
Hi Guys,
For the second time in 2 months we have problem with our publisher. Publisher is reachable via ping and SSH but doesn't working anymore.
In console we have the following:
WARNING:
The /common file system is mounted read only.
Please use Recovery Disk to check the file system using fsck.
login as: osadministrator
osadministrator@10.151.143.71's password:
Last login: Fri Sep  7 11:42:34 2012 from 10.151.136.166
Command Line Interface is starting up, please wait ...
java.io.FileNotFoundException: /var/log/active/platform/log/cli.bin (Read-only file system)
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:212)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.restoreIndex(ciscoRollingFileAppender.java:100)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.setFile(ciscoRollingFileAppender.java:43)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.java:196)
at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.java:155)
at org.apache.log4j.xml.DOMConfigurator.setParameter(DOMConfigurator.java:530)
at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.java:182)
at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:140)
at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfigurator.java:153)
at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOMConfigurator.java:415)
at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:384)
at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:783)
at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:666)
at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:616)
at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:584)
at org.apache.log4j.xml.DOMConfigurator.configure(DOMConfigurator.java:687)
at sdMain.main(sdMain.java:599)
java.lang.NullPointerException
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.updateIndex(ciscoRollingFileAppender.java:117)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.nextFileName(ciscoRollingFileAppender.java:92)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.append(ciscoRollingFileAppender.java:74)
at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:221)
at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders (AppenderAttachableImpl.java:57)
at org.apache.log4j.Category.callAppenders(Category.java:187)
at org.apache.log4j.Category.forcedLog(Category.java:372)
at org.apache.log4j.Category.info(Category.java:674)
at sdMain.main(sdMain.java:613)
log4j:ERROR No output stream or file set for the appender named [CLI_LOG].
Welcome to the Platform Command Line Interface
WARNING:
admin:
The server was not stop or power problem, just "bug" suddently.
One of you already facing this issue ? On the bugtool from Cisco's website (if i'm using it right) I found nothing.
Thanks for your help.
Hervé Jacquemin
Rob Huffman
Hi Hervé,
There are some bugs that can manifest in this behavior. We would need
to know your CUCM version and exact server model to assess the exact
issue
Here is one example;
Field Notice: FN - 63270 - MCS-7835-I2, MCS-7845-I2, RAID Driver can cause Service Outage, SW upgrade required
http://www.cisco.com/en/US/ts/fn/632/fn63270.html
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Rob Huffman
Hi Hervé,
issue
Cheers!
Rob
