PVDM Sharing FX0 and E1
mlmyambao
I have a 2911 Router with 3 modules of VIC2-4FXO and 1 module of VWIC3-4MFT-T1/E1. Is there a way to enable PVDM Sharing accross all analog and digital ports? The PVDM3 DSP DIMM installed on the router has only 16 Channels.
Aaron Harrison
Analogue ports get the DSPs assigned at startup, and the remaining can be used by your E1. It sounds like your router is simply under provisioned, you'll need more DSPs if you need more than 12 channels on your E1.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
