Q IPCCX
user-cisco
hi
i have a simple question on IPCCX scripting:
i want to build a script that will route a list of calling numbers (VIP List) to specific agents while all other callers to a CSQ.
my question is that how and where to assign the ANI list of those VIP callers in a script
i tried to add a variable called ANI with a condition of ANI.startsWith
but i want some kind of ANI equals list of VIP ANI numbers?
please help?
6 Replies 6
kelvin.blair
Level 5
Level 5
You should be able to write a script that matches the Call Contact Info to an varible. From there, you should be able to if then statement matching on the numbers. You might need to write a If then statement for everyone ANI match. I think it should look something like so:
Get Call Contact and write it to variable X.
If Variable X == "X" then X.
Hello everyone,
I need the help for the following situation:
I need to create a filter so that only 2 agents(resources) receive calls from a number location.
I have 25 agents(Resources) and i need to only 2 agents(Resources) receive calls from this particular location.
So i created this steps in my IPCC Express.
First:
1- Create another Skill ( New_Skill )
2- Create another CSQ ( New_Queue )
3- Assign the New_Skill to all 2 Agents .
4- Make the CSQ is Skill routing based and add the New_Skill into the New_Queue .
I create a script for check the calling number and send to a CSQ_Queue:
Second:
Label:CSQ_New
Select Resource(--Triggering Contact--, CSQ_New)
ANI = (Get Call Contact Info (--Triggering Contact--, Calling Number)
If ANI == 085 then
True
Goto CSQ_New
False
Goto Queue
Will this script work?
Thank you!
Bruno.
Any sugestions about this??
Can anyone help??
Hi Bruno,
Yes that script logic should work ok.
You might have received more replies if you posted in the Contact Center forum
Thank you so much James!!
I'm new in this forum, and i will posted in Contact Center now!!
Thanks again!!
