Question about GK redundancy.
Hi all,
I just wanted to know which the best method for a Gatekeeper routing fail is over
For example I have 2 CUCM’s
  • CUCM_viti_1
  • CUCM_viti_2
Registered as an endpoint for our gatekeeper.
So, whenever a call try to establish a connection to an extension 0826*, I configure my GK with the following settings.
zone prefix gk2 0826* gw-priority 10 cucm_viti_1 cucm_viti_2
Meaning that if cucm_viti_1 is not available, it will failover to cucm_viti_2
BUT
What is the difference of using?
zone prefix gk2 0826* gw-priority 9 cucm_viti_2
Please tell me an advise, in when should I use each scenario.
Regards.
Ayodeji Okanlawon
The first scenario assigns the same priority to both cucm. hence calls will be distributed in a round roboin fashion. The second command makes CUCM_viti_1 as the primary cucm since it has the higer priority and only when this is down will calls be sent to the second cucm
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ayodeji Okanlawon
Your explanation was useful.
I Imagined that so, like Media Resource Groups and Media Resource Lists. in CUCM
Thank you
Kudos to Aoklanawon! :-) +5
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
