"vsacount in free is 0" error when receiving calls
usinadelta
Hello, I would like some help from you!
I have a CISCO 2921 SIP router and I'm having problems receiving calls, but I'm able to make calls normally, I checked other community posts and saw a lot about MGCP, but on my router it's disabled.
It's not a problem, because the other unit is also disabled and the connections are working normally. In the log I collected, the error "vsacount in free is 0" appears.
19 Replies 19
You need to make sure  the translation is happening and the call is hitting on the dial-peer made towards CUCM.( dial-peer 101 & 100)
Response Signature
When doing a call test, I see that the call hits the gateway but does not complete the connection, the debug is attached.
The translation is not happening. the calls is hitting on dial-peer 0 which is the default and its not good practice to hit on Dial-peer 0.
  Calling Number=34988884645,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=33315730(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Make the call to hit on a incoming dial-peer  where the translation is applied.  And you issue will be solved.
Response Signature
Could you explain to me how I make the call access a different dial peer?
Daniel Bosch
Not sure if you've given up, or have this resolved now.  If the former, you're still missing some required elements:
1. Still no inbound dial-peer to match called numbers 33315....
2. Voice translation-profile DDRCEL isn't even applied to any dial-peers.
3. If you create an inbound peer and apply profile DDRCEL, it should be configured to 'translate called 5799' not "translate calling..."
Try adding these to router config:
config t
voice translation-rule 5799
no rule 1
no rule 2
rule 1 /^3331\(5...\)/ /\1/
rule 2 /^\(57..\)/ /33315799/
rule 3 /^33315700/ /33315799/
voice translation-profile DDRCEL
no translate calling 5799
dial-peer voice 5799 voip
translation-profile incoming DDRCEL
session protocol sipv2
incoming called-number 33315...$
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay sip-kpml sip-info sip-notify rtp-nte
