RDP issues
moe2
Hi Members,
I do have a question regarding remote destination profile and remote destination (Mobility Connect). The scenario is I do have a range of DID from provider and range of DN numbers that are can make calls locally only (internal DNs). we are using SIP.
Phone A has an option RD activated can call to Mobile
Phone B has DID phone.
Phone C have internal DN (Local extension).
Now when B calls A Mobile rings no problems.
but when C calls A mobile does not ring! provider blocks number not in the DID range.
I thought of few solutions and please can you verify them if it is possible or the best solution to this problem.
1- Can I when C calls A make the mobile ring using A's extension number?
2- Can I forward A to D (DID number) when C calls A transfer's from C to D and make D (DID number) make the call to mobile.
3- Or change route pattern or translation pattern new partition new CSS. like Should I create group DNs that linked to DID when external calls needed. if so how is it done?
What do you guys recommend?
many thanks.
Ratheesh Kumar
Hi there
Could you try adding your main pilot number of any DID number as the External Number Mask on Phone C and see that helps.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Unfortunately, it did not help or even change anything. Now I am just even trying to forward all calls to cell phone it is not even working! from DID number i can only forward to an internal number.
This is mostly your ITSP issue. They might be blocking your call.
Hope this helps!
Cheers
Rath!
