04-04-2018 12:21 PM - edited 03-17-2019 12:33 PM
I need to reinstall a fresh copy of cucm on an existing CUCM VMware build - test lab . Though it is installed I need to rebuild it again, I thought the way to do it was the same as build
Point the drive to location of the bootable SW
Power on
And in theory the system should carry out a fresh install over the top - however it fails and it just brings it up as a normal CUCM without the fresh build process , what am I missing ?
Many thanks
04-04-2018 01:06 PM
What you are seeing is exactly what I would expect to happen.
Can you provide more details on what you think should be happening.
04-04-2018 01:19 PM
I need to reinstall a fresh cucm on top of an existing version - the same version is being installed again. But when I boot up the server after pointing it to same sw which was used to install it originally,it boots up normally. I thought it would try to reinstall itself again
04-04-2018 01:49 PM
You need to delete your VM and create a fresh VM for that.
04-04-2018 02:20 PM
If I delete the VM, does it keep all the vlan,network address etc. Is it just the case of installing the ova again then the iso?
Next question
If I'm using it as a test install first to test some features then going to reuse the same VM as production afterwards, would you recommend using a snapshot before I install the initial Cisco SW before I build the test system and then restore the original VM after the test build and then build it again as production or delete the VM and rebuild via the ova so if is clean?
04-04-2018 04:24 PM
if you delete a VM you delete EVERYTHING,
You need to deploy the OVA from cisco.com, and then you perform a fresh install.
Snapshots are NOT supported, review what is supported and what not in the virtualization wiki.
04-05-2018 12:29 AM
I thought I saw somewhere that deleting the VM instance allows me to re-install a new ova for a fresh install of VOS? It kept the networking be set up in place?
04-05-2018 01:19 AM
Sorry, I mean delete from disk
04-05-2018 03:03 AM
If you would like to retain the data from the VM, you can use the Export BAT feature to export pretty much everything you configured. As long as the new system is the same version it should import with zero problem.
04-05-2018 03:01 AM
Are you setting the boot order to boot to the ISO before the disk?
