06-05-2024 06:28 AM
Little background: Recently E911 call failed in our environment. CER Pub GUI was not accessible for some reason and Sub was not taking over. Calls went through after restarting both servers from CLI. We found later from TAC that we lost the logs after the reboot that could tell us what caused the issue.
Now, we are considering establishing a routine daily test call to 911 from a specific test DN but instead of sending such calls to PSAP, I would like to re-route that call back from CUBE to a DN or IVR in our CUCM based on calling number, without affecting actual 911 calls. This way we can confirm calls are hitting the CUBE but routing them back to an internal extension.
Can someone tell me what I need to do in CUBE without affecting normal call flows. Is it all about dial peers or something else is required? Or is there a better way to test/simulate 911 calls.
Solved! Go to Solution.
06-06-2024 07:29 AM - edited 06-06-2024 07:30 AM
Something along the way with this should work.
voice class e164-pattern-map 200
description E164 Pattern Map for calling number 5555
e164 5555
voice class dpg 200
description Dial-peer Group for specific calling number 5555
dial-peer 200
voice translation-rule 200
rule 1 /^911$/ /4444/
voice translation-profile TEST911-OUT
translate called 200
voice class server-group 1
ipv4 <CM IP 1> preference 2
ipv4 <CM IP 2> preference 1
ipv4 <CM IP 3> preference 3
description Inbound calls to CUCM
huntstop 1 resp-code 404 to 404
voice class sip-options-keepalive 1
description Used for Server Group SIP OPTIONS PING
dial-peer voice 100 voip
description Incoming Dial-Peer from 5555
session protocol sipv2
destination dpg 200
incoming calling e164-pattern-map 200
voice-class codec 1
dtmf-relay rtp-nte sip-kpml
no vad
dial-peer voice 200 voip
description Outbound Dial-Peer to CM for test 911 calls
translation-profile outgoing TEST911-OUT
session server-group 1
destination-pattern BAD.BAD
voice-class codec 1
voice-class sip options-keepalive profile 1
no vad
06-08-2024 07:50 AM
After thinking of what you wrote again I think that I might have misread your post. The issue that you brought forward is if I’m not mistaken that you can’t make the match in the inbound direction for the 5555 calling number since CER changes it to an ELIN. With that I think you’d need to configure the testing device to be in a specific location so that it presents a specific ELIN, it doesn’t even need to be a proper DID number as the call would never be sent to PSAP. Then change the E164 map used to match the calling number to this ELIN. That should make this work as you want it.
06-05-2024 06:51 AM
If you’re making the call from a specific directory number and that number isn’t going to be used for anything else you’ll need to create a specific dial peer that is to be used in the inbound direction. On this dial peer use DPG configuration to send the call to one or more dial peer(s) that passes the call back to CM. In CM you’ll then need to construct a set of translation patterns to use the route by calling number function that CM have. As an alternative you could use a specific dial peer on the outbound direction in your SBC to modify the called number from 911 to the DN you want to receive the call in CM. That way you don’t have to use the route by calling number construct in CM. This would IMO be a simpler solution.
06-06-2024 06:51 AM
What's the current dial-peer you have for matching 911 calls?
To match calls based on calling number in CUBE we can use answer-address, however this has the least preference in matching, the incoming called-number takes priority.
06-06-2024 07:25 AM
Here is our existing DP for 911 calls.
dial-peer voice 911 pots
trunkgroup Local
description Emergency Services Calls
destination-pattern 911
forward-digits all
Do you think we can make use of translation profile to get around this issue like :
create a translation profile to translate 911 called number to lets say 999 and apply that to inbound leg and route call back to CUCM for 999?
06-06-2024 06:58 AM
Thanks a lot Roger for the ideas. Greatly appreciated. Could you elaborate more on dial peer on outbound direction in SBC as you stated. As I mentioned in my post, I only want to route the 911 call from that specific extension lets say 5555 to another extension 4444 once call arrives at the CUBE. I can create specific inbound dial peer to match the calling number. However, not sure what would the outbound dial peer (cube to cucm leg) be like. I want to do it without affecting normal call flows including 911 for the rest of the users.
e164 5555
voice class dpg 200
dial-peer 200
destination dpg 200
voice-class codec 1
no vad
voice-class codec 1
no vad
06-06-2024 07:43 AM
Excellent. This looks very promising. I will test it in my lab environment and update here how it goes. Thank you so much for your help all the time.
Khanal
06-06-2024 02:16 PM
For additional details on how call routing works in IOS please have a look at this great document. Explain Cisco IOS and IOS XE Call Routing
06-07-2024 11:29 AM
I ran into an issue while testing a 911 call. I was expecting the calling number in my cube but as the number goes through cube, the calling number is modified by CER and at the end only the number defined as ELIN is what is received at the cube as the calling number. Since I want to simulate actual 911 call (phone->cucm->cer->cucm->cube) I wonder if there is a way to send the actual number of my phone to cube without CER replacing with ELIN.
KhanalZ
06-07-2024 05:12 PM
So you wanted to do the test to see if CER is operating so by that you’ll need the call to go through it and then it will do its thing. Can you not just add another translation to match the ELIN you say CER is sending and translate that into the calling number you want?
If you add something like this it should do that. You’ll need to modify the rule to fit your needs.
voice translation-rule 210
rule 1 /^<ELIN>$/ /<ANI you want to be presented>/
translate calling 210
06-08-2024 07:50 AM
06-10-2024 08:53 AM
Roger, your last response makes perfect sense now. Translation profile wouldn't help because it will mess up genuine 911 calls. Now I will need to figure out the way so that when 5555 calls, CER will assign it a dedicated ELIN and I should be able to route that call back from CUBE to 4444 with much ease. BTW appreciate you taking your time to help me.
KhanlaZ
06-10-2024 07:11 PM
Glad to hear that. However the translation on the dial peer I suggested used by the DPG would not break normal 911 calls as that dial peer doesn’t really match 911 calls.
