06-05-2024 06:28 AM
Little background: Recently E911 call failed in our environment. CER Pub GUI was not accessible for some reason and Sub was not taking over. Calls went through after restarting both servers from CLI. We found later from TAC that we lost the logs after the reboot that could tell us what caused the issue.
Now, we are considering establishing a routine daily test call to 911 from a specific test DN but instead of sending such calls to PSAP, I would like to re-route that call back from CUBE to a DN or IVR in our CUCM based on calling number, without affecting actual 911 calls. This way we can confirm calls are hitting the CUBE but routing them back to an internal extension.
Can someone tell me what I need to do in CUBE without affecting normal call flows. Is it all about dial peers or something else is required? Or is there a better way to test/simulate 911 calls.
Solved! Go to Solution.
06-06-2024 07:29 AM - edited 06-06-2024 07:30 AM
Something along the way with this should work.
voice class e164-pattern-map 200
description E164 Pattern Map for calling number 5555
e164 5555
voice class dpg 200
description Dial-peer Group for specific calling number 5555
dial-peer 200
voice translation-rule 200
rule 1 /^911$/ /4444/
voice translation-profile TEST911-OUT
translate called 200
voice class server-group 1
ipv4 <CM IP 1> preference 2
ipv4 <CM IP 2> preference 1
ipv4 <CM IP 3> preference 3
description Inbound calls to CUCM
huntstop 1 resp-code 404 to 404
voice class sip-options-keepalive 1
description Used for Server Group SIP OPTIONS PING
dial-peer voice 100 voip
description Incoming Dial-Peer from 5555
session protocol sipv2
destination dpg 200
incoming calling e164-pattern-map 200
voice-class codec 1
dtmf-relay rtp-nte sip-kpml
no vad
dial-peer voice 200 voip
description Outbound Dial-Peer to CM for test 911 calls
translation-profile outgoing TEST911-OUT
session server-group 1
destination-pattern BAD.BAD
voice-class codec 1
voice-class sip options-keepalive profile 1
no vad
06-08-2024 07:50 AM
After thinking of what you wrote again I think that I might have misread your post. The issue that you brought forward is if I’m not mistaken that you can’t make the match in the inbound direction for the 5555 calling number since CER changes it to an ELIN. With that I think you’d need to configure the testing device to be in a specific location so that it presents a specific ELIN, it doesn’t even need to be a proper DID number as the call would never be sent to PSAP. Then change the E164 map used to match the calling number to this ELIN. That should make this work as you want it.
08-07-2024 12:13 PM
If you read the document that I shared with you on the 6:th of June you would see the order of matches for calls on dial peers. URI match is higher in priority than incoming calling number.
Also as you haven’t shared your complete running configuration it’s not possible for anyone on the community to know what other dial peers you might have that could affect the proposed solution. If you want to get a full rundown of your configuration please share it in an attached plain text file.
08-08-2024 01:03 PM
Please share your complete running configuration and the output from these debugs running all in parallel, debug ccsip message, debug ccsip non-call, debug voip ccapi inout, debug voip dial-peer and debug voip translation in two separate text files.
06-05-2024 06:51 AM
If you’re making the call from a specific directory number and that number isn’t going to be used for anything else you’ll need to create a specific dial peer that is to be used in the inbound direction. On this dial peer use DPG configuration to send the call to one or more dial peer(s) that passes the call back to CM. In CM you’ll then need to construct a set of translation patterns to use the route by calling number function that CM have. As an alternative you could use a specific dial peer on the outbound direction in your SBC to modify the called number from 911 to the DN you want to receive the call in CM. That way you don’t have to use the route by calling number construct in CM. This would IMO be a simpler solution.
06-06-2024 06:51 AM
What's the current dial-peer you have for matching 911 calls?
To match calls based on calling number in CUBE we can use answer-address, however this has the least preference in matching, the incoming called-number takes priority.
06-06-2024 07:25 AM
Here is our existing DP for 911 calls.
dial-peer voice 911 pots
trunkgroup Local
description Emergency Services Calls
destination-pattern 911
forward-digits all
Do you think we can make use of translation profile to get around this issue like :
create a translation profile to translate 911 called number to lets say 999 and apply that to inbound leg and route call back to CUCM for 999?
06-06-2024 06:58 AM
Thanks a lot Roger for the ideas. Greatly appreciated. Could you elaborate more on dial peer on outbound direction in SBC as you stated. As I mentioned in my post, I only want to route the 911 call from that specific extension lets say 5555 to another extension 4444 once call arrives at the CUBE. I can create specific inbound dial peer to match the calling number. However, not sure what would the outbound dial peer (cube to cucm leg) be like. I want to do it without affecting normal call flows including 911 for the rest of the users.
e164 5555
voice class dpg 200
dial-peer 200
destination dpg 200
voice-class codec 1
no vad
voice-class codec 1
no vad
08-07-2024 11:55 AM
I tested with above configuration but it didn't work the way it was expected. Incoming call from CUCM does not match the dial peer 100 but it matches another dial peer which uses voice class URI. And as a result, dial peer 200 is not matched. Is it because URI takes precedence over other methods? What options do I have to make it work without breaking the prod system?
08-07-2024 12:13 PM
08-07-2024 03:12 PM
I have attached the subset of the config relevant to this issue. For privacy reason, I have modified certain information.
Here, I setup a test phone with the number 5555552222. I have configured e.164 pattern, dpg, translation pattern and dial peers as per your recommedation. Per translation rule 200, if i call 92024655568 from my test phone it should translate to +15555552224 and ring an IVR i have setup for the testing purpose. I choose to translate 92024655568 in place of actual 911 number because I wanted to avoid CER in the call path.
When I checked the logs, I find the inbound call matching DP 10 and outbound matching 9101. Since DP 10 uses URI, I know it takes precedence and no further matching takes place.
I would be so grateful if you could provide the solution without requiring to make big changes in the existing config.
Thank you
08-08-2024 12:30 AM - edited 08-08-2024 12:39 AM
You need to change the way you match inbound calls on DP 10 so that it has an equal match priority of your new inbound dial peer. To do so and still have that dial peer match any other calls than the specific test number you can do something like this.
voice class e164-pattern-map 10
e164 +T
e164 .T
dial-peer voice 10 voip
no incoming uri via 10
incoming calling e164-pattern-map 10
Apart from this there is no need for you to have a specific dial peer for 4 digit calls to CM. You can combine the patters in the 1000 and 1001 e164 dial plan maps to have DP 1000 handle both calls in +E.164 format and 4 digit format. With that you can simplify your configuration and remove dial peer 1001 and the 1001 e164 dial plan map.
08-08-2024 09:21 AM
Even after making the changes you recommended the inbound call still matches DP 10 instead of DP 100. Following is the config
voice class e164-pattern-map 1000
e164 +124040610..
e164 +1555555222.
e164 +T
e164 .T
description E164 Pattern Map for calling number +15555552222
e164 +15555552222
rule 1 /^920224655568/ /+15555552224/
rule 2 /^9120224655568/ /+15555552224/
rule 3 /92024655568/ /+15555552224/
rule 4 /912024655568/ /+15555552224/
description CUCM-Inbound
voice-class codec 1
fax-relay ecm disable
fax nsf 000000
ip qos dscp cs3 signaling
no vad
destination dpg 200
voice-class codec 1
no vad
session server-group 1000
voice-class codec 1
no vad
08-08-2024 10:15 AM
Change to this then to not have it match the specific number that you use for your test.
e164 +124040610..
e164 +15555552221
e164 +15555552223-9
08-08-2024 12:46 PM
Even after only keeping +124040610.. in pattern map 10 and applying that to DP 10 and calling from the different test number 5555552225 number gave the same result. still it matches dp 10
description E164 Pattern Map for calling number +15555552225
e164 +15555552225
voice class dpg 200
description Dial-peer Group for specific calling number +15555552225
dial-peer 200
08-08-2024 01:03 PM
08-08-2024 05:21 PM - edited 08-08-2024 05:22 PM
Sorry to bother but I know the solution you provided should work and it has infact worked in my other test environment. Of course I didn't try there with all the dial peers that i have in prod but hoped it would just work fine in the prod. Anyway, as I keep trying this and that,
Received:
INVITE sip:912024655568@10.16.10.19:5060 SIP/2.0
Via: SIP/2.0/TCP 10.16.10.13:5060;branch=z9hG4bK86ccfa31f6df54
From: "test" <sip:+15555552225@test.com>;tag=29825751~d64c732d-9f48-42f9-b0e8-25f1bf3b6a0b-90569150
To: <sip:912024655568@10.16.10.19>
Date: Thu, 08 Aug 2024 23:58:33 GMT
Call-ID: 1d042000-1f0173e5-8612ab-82ef6a0a@10.16.10.13
Interface=0x7FEE5323F8D8, Call Info(
Calling Number=sip:+15555552225@test.com,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Network, Presentation=Allowed),
Called Number=sip:912024655568@10.16.10.19:5060(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Relevant configs are here
e164 +15555552225
e164 +15555552225T
voice class dpg 200
dial-peer 200
destination dpg 200
voice-class codec 1
no vad
I just realized that the calls never hit the inbound dial peer 100 even after shutting down dial peer 10 which is strange. It matches dial peer 0 as given above:
