Reasons for Auth Fail message
Grayson Wells
What are the reasons for an Auth Fail message when the phone is trying to load firmware? I know you can get that message if you didn't put the correct MAC address in the CUCM or if you have the model number wrong, but I have verified both of those things and I still get the auth fail message. The phone still boots up, but with a later firmware image.
Rob Huffman
Hi Robert,
You will usually see this when the current firmware that is running on the IP Phone
is too old to move to a newer version. For example....we know that to move to a Firmware
like 9-0-3S you must be at a minimum of 8-3-3. If you were at 8.3.2 when you
went to move to 9-0-3S you would see "Auth Fail" on the phone display and the Firmware
would not upgrade.
Hope this makes sense
Cheers!
Rob
Rob Huffman
Hi Robert,
would not upgrade.
Cheers!
Rob
Makes sense, thanks!
