07-15-2016
10:11 AM
- last edited on
03-25-2019
08:40 PM
by
ciscomoderator
Hi All,
What is the recommended sequence for the shutting down and restarting of Publisher, Subscriber, UCCX, Presence and Unity servers. The phones are currently registered to the subscriber.
07-15-2016 10:35 AM
I've been using this sequence and it's worked well:
07-16-2016 04:56 AM
There is no specific order you need to follow, so it's really up to you, if you don't care about keeping up redundant services while servers are rebooting you can do all of them at the same time.
07-17-2016 11:10 PM
Hi Rahul,
If it is only a simple reboot and does not involve any switch version or cop file install scenario then as Chris mentioned it really does not matter. It is however good if you restart the Publisher first and then the subscribers. If the reboot involves switching version or any platform changes then you should check the compatibility of all apps to ensure they remain compatible and are rebooted in the same maintenance window.
Manish
