09-22-2012 03:27 AM - edited 03-16-2019 01:20 PM
Hi Guys,
I am using C881-CUBE-k9 router and would like to register 2 SIP lines from the same provider, currently I can only register one. Any suggestions why I cant register 2 SIP lines ?
Config Attached:
Any help would be really appreciated.
Solved! Go to Solution.
09-22-2012 03:44 AM
The configuration looks okay. So what happens with this line...How do you know the line is not registered?
can you send the output of
show sip-ua register status
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
09-22-2012 03:44 AM
09-22-2012 04:12 AM
Hi Mate,
show sip-ua register status - line is not registered. (This line was registered and working for a while. Once I tried to register the second sip line, the first line cannot register either ?)
What is your suggestion about registering 2 SIP lines using the same provider ? is this possible ?
Cheers
09-22-2012 05:01 AM
please send...
debug ccsip messages
09-22-2012 02:50 PM
Hi Mate
I cant send you the debug ccsip message until tomorrow.
Do you know if I can register 2 SIP lines from the same provider on Cisco881-CUBE-k9 router ?
Cheers
10-08-2012 03:00 PM
Cisco does not support registering 2 sip trunks from the same provider.
10-08-2012 05:37 PM
And where Cisco says that?
10-08-2012 07:11 PM
Hi Paola,
Product: Cisco881-CUBE-k9
I spent some time talking to Cisco Tac team
1) Each time I register a second sip username & password it overwrites the first one.
2) Unless you use different service provider for each sip line with different realms.
I could not find any document that provides any information on how to register 2 SIP authentications with the same SP and using the same realm.
Cisco Tac has confirmed the above cannot happen on Cisco881.
If you think Cisco can support this, it will be great if you can send me some documentation on it.
Syed
