Register a SIP device with CME?
comjf
I have a 2811 with CME 4.2 that is working fine for SCCP handsets, but I would like to use a couple of (non-Cisco) SIP devices. Is this possible? I can't find any good documentation on whether this is even possible, let alone how to do it!
I am partway there, but when my SIP device tries to login it gets a 503 message back from CME:
SIP/2.0 503 Service Unavailable - registrar unavail or not enabled
I think this means it is trying to pass the registration off to an external SIP registrar, but I have not configured one. Can I make the CME router a SIP registrar?
Michael.
28 Replies 28
mohamedtag
Hello ,
I tried it and it worked using a GrandStream SIP IP Phone. As far as i remember , i defined the Phone Type = 7905..I will try to get the Exact Configuration on the CME and submit it.
M.Tag
firebadger
It is certainly possible - if you have a search of these forums (on the right) you will see that many before you have asked similar questions.
Are you sure this is CME 4.2? And not CME 4.0(2)? Sorry to teach you to suck eggs, but I wasn't aware of a release >4.1 :) (if it really is 4.2, which IOS image are you using?)
As for the registrar, a quick clue would be the 'voice service voip', where you can define the register address.
Also, remember that you need to setup the 'voice register globals' with 'mode cme', and all corresponding values.
As well as that, curiously, the SIP registrar in CME mode *must* have the MAC address of the phone connecting, which SIP phones will not send (and aren't supposed to!)
You can rectify this by adding an arp entry, and a /32 static route for each phone (tedious, but it works).
FINALLY. I'm using 12.4(15)T, with CME 4.1. I tried to register a Snom 360 yesterday and it crashed the router SIX times before I realised what was going on. Today, a Mitel phone is giving me grief (though not as bad as the Snom) and on top of all that, I have a Grandstream sat here working quite well.
Still, the voice register dialplans are a mess - I wouldn't recommend SIP phones on CME 4.1, at all.
Hi Fire,
the issue is solved, look above :)
and yes there is CME 4.2, that is 12.4(11)XW1.
the MAC address is needed only for phones on LAn directly connected to the router, for the remote ones it can be all zero, but authentication is required. But, if you do the ARP trick as you said, not authentication will be required!
Congratulations on you router crashes and interop testing!
I am using 12.4(11)XW2
It seems that I spoke too soon :( I cannot place calls between two SIP devices. One of them is a 7960 running SIP firmware and the other is a software client.
When I place a call from the 7960 to the PC the PC rings but a reorder tone is generated at the 7960 when the PC answers.
When I place a call from the PC to the 7960, I get call not authorised displayed on the PC. A packet capture does not show any packets at all between the PC and CME though :S
sh voice register dial-peers shows both devices registered with the expected IP Addresses and ports. I have tried a few different debugs, but all seems normal.
Any pointers gratefully received :D
Let's try at least to have at some debugs. As you probably know, "term mon" and "debug ccsip message".
What is the software client? E.g. xlite is know to work well.
Sorry, the software client is X-Pro.
I have been trying some more debugs. Attached is debug ccsip message when calling from 7960 to X-Pro.
I just noticed the 500 Server Internal Error (from the 7960?).
The X-Pro client requires that a realm be defined, but I can't see where to configure one in the 7960. Does this matter? It seems to be registered OK:
sh voice register pool 3
Pool Tag 3
Config:
Mac address is 0015.62EA.714E
Type is 7960
Number list 1 : DN 1
Proxy Ip address is 0.0.0.0
DTMF Relay is disabled
Call Waiting is enabled
DnD is disabled
keep-conference is enabled
username 414 password 1234
service-control mechanism is not supported
registration Call ID is 001562ea-714e0011-67f29751-6b1f918e@192.168.61.10
active primary line is: 414
contact IP address: 192.168.61.10 port 5061
Dialpeers created:
dial-peer voice 40002 voip
destination-pattern 414
session target ipv4:192.168.61.10:5061
session protocol sipv2
voice-class codec 1
after-hours-exempt FALSE
Statistics:
Active registrations : 1
Total SIP phones registered: 2
Total Registration Statistics
Registration requests : 2
Registration success : 2
Registration failed : 0
unRegister requests : 0
unRegister success : 0
unRegister failed : 0
Here is my config:
voice service voip
allow-connections sip to sip
redirect ip2ip
sip
registrar server
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
mode cme
source-address 192.168.61.1 port 5060
max-dn 144
max-pool 36
authenticate register
authenticate realm c5.com
voice register dn 1
number 414
name SIP Test
voice register dn 2
number 415
name SIP Test2
voice register pool 2
id mac 1234.1234.1234
type ATA
number 1 dn 2
voice-class codec 1
username 415 password 1234
id mac 0015.62EA.714E
type 7960
number 1 dn 1
voice-class codec 1
TIA
A couple more questions:
Do I need to have PVDMs in my 2811 if there are no voice modules?
Do I need to configure transcoding/dspfarm resources if the SIP clients negotiate the same codec?
Can I force the 2811 to act as a proxy instead of allowing direct connections between the SIP endpoints?
Q1 and Q2: no.
Q3: In Cisco parlance, this is called "media flow-around" as opposed to "media flow-through".
Per documentation, CME supports only flow-through as you can see from SDP portion of SIP invite.
although "voice class codec" appears correctly configured, can you try "codec g711u" instead of "voice-class codec", under both "voice register pool" ?
OK, that is a little closer, although I am not sure why the voice class doesn't work!
I can now call from 7960 (SIP) to X-Pro and from 7960 to IP Communicator. I can also call from IP Communicator to both SIP clients.
I cannot call from X-Pro to any SIP or SCCP clients. Debug ccsip messages does not produce anything when I attempt this and the X-Pro display shows Call not approved. the config in X-Pro is:
Display Name: 415
Username: 415
Authorisation user: 415
Password: 1234
Domain/Realm: c5.com
SIP Proxy: 192.168.61.1
Out Bound Proxy: 192.168.61.1 (seems to make no difference)
Use Outbound Proxy: Default
Send Internal IP: Default
Register: Always
Voicemail SIP URL:
Forward SIP URL:
Use Voicemail: Forward to Voicemail
Direct Dial IP: No
Dial Prefix: #1
I think it is correct? I have also tried with Send Internal IP: Always and Use Outbound Proxy: Never.
TIA
Glad to know things started working. The thing is that SIP on IOS is a best, "a little iffy". What IOS are you using?
Not being able to call from X-pro must be an issue with itself, as the lack of any debug output at the router demonstrates. In X-lite, below the user details, I have "register with domain" and "Send outbound via proxy" close to the CME address. And it works fine.
Thanks for the nice rating and good luck!
I have alos the problems with X-lite Softphones using SIP.
I have registered 2 SIP x-Lite Softphones and I am bale to call from Cisco IP Phone to X-Lite Phone, but not able to call from X.lite to Cisco IP Phone and X-lite to X.lite,
In the attachment there is my configuration,
When I want to call From X-Lite I get the message: Call Failed:Not acceptable media
regards,
alicic
hi
thanks for your config .
i can now call between both the type of phones.sccp and sip
the main thing that came out is that u should define on g711u law codec.
remove rest if u have on xlite.
regards
hi i tried your config and did some edit ..
just copy and paste.
may b it will help.
thx to all this conversation has resolved issues for lots of people.
